Audi A3/S3/RS3 8V Coding DataBase - Updating!
Not open for further replies.
DJAlix
VAG CAR CODING
Site Sponsor
VAG Can Professional
ODIS (Offboard Diagnostic System)
The Garage, Dukes Mews, London N10 2QP
Website
vagcarcoding.com
Coming soon, a comprehensive database of coding for the Audi A3/S3/RS3 8V!
  • This thread is not intended be used as a Coding Software Application user manual and does not detail information needed for use.
  • The creator of this thread has no affiliation with any Coding Software Application Software.
  • Before attempting any of the Adaptations and or Codings contained within this thread please make sure that you are familiar with the workings and the operation of your chosen Software Application and it’s potential implications, issues and effects.
  • If you are unsure of or indeed have any doubts relating to any of the Adaptations and or Codings contained within this thread please do not continue any further and seek advice from an Audi specialist or professional, a reputable internet support forum or the makers of your chosen Coding Software Application.
  • Reasonable care has been used in both creating and collating the information included within this document, but this does not warrant that such information is error free. You, the user of this thread, are responsible for any and all complications, issues and effects which may arise following the completion of any Adaptations and or Codings contained within this document in relation to your or any persons vehicle. Should you choose to complete any of the detailed Adaptations and or Codings you perform any and all modifications strictly and entirely at your own risk.
  • In no event will the creator of this thread be liable for any loss or damage including without limitation, indirect or consequential loss or damage, or any loss or damage whatsoever arising out of, or in connection with, the use of this thread.
  • The creator of this thread does not condone the use of 3rd Party, Cloned or hacked Software Applications. Please Support Genuine Tools and the future development of the Software and Hardware by purchasing and only using a Genuine Tools
  • Please note that some of the Adaptions and Codings contained within this thread may invalidate your vehicle's manufactures standard limited warranty.
  • Please note that some, if not all of the Adaptations and Codings contained within this thread will not be supported by Audi and affiliated partners.
  • Please note that some of the Adaptations and Codings contained within this thread may contravene road and vehicle laws within your country of residence.
VAG Car Coding™ Limited
Reactions: Mixmeister, AlS3BE, Harvey and 3 others
Acoustic Alarm MMI Menu
  1. Control Module 09 - Central Elect
  2. Security Access - 16
  3. 31347
  4. Adaption - 10
  5. Menuesteuerung akustische Rueckmeldung
  6. Active
Reactions: Mixmeister, AlS3BE and 8YARWY
Acoustic Alarm On Lock
  3. 31347
  4. Adaption - 10
  5. Akustische Rueckmeldung Verriegeln
  6. Active
Acoustic Alarm On Unlock
  3. 31347
  4. Adaption - 10
  5. Akustische Rueckmeldung entriegen
  6. Active
Visual Conformation of Comfort Closing
  3. 31347
  4. Adaption - 10
  5. gptische Rueckmeldung Komfortschliessen
  6. Active
Oil Temperature Display (within all DIS menus)
  1. Control Module 17 - Instruments
  2. Coding - 07
  3. Long Coding Helper
  4. Byte 10
  5. Bit 1 = Activate
Reactions: Mixmeister and 8YARWY
Wiper Service Position MMI Menu
  3. 31347
  4. Adaption - 10
  5. Menuesteuerung Frontwischer
  6. Active
Throttle Response / Throttle Behaviour Method
  1. Control Module 44 - Power Steering
  3. 19249
  4. Adaption - 10
  5. Driving Profile Switchover
  6. Direct
Automatic Rain Closing
  3. 31347
  4. Adaption - 10
  5. Regenschliessen_ein aus
  6. Active
  7. Regenschliessen_art
  8. Permanent
  9. Menuesteuerung Regenschliessen
  10. Active
Reset MMI
  • Control Module 09 - Central Elect
  • Coding - 07
  • Select RLHS
  • Long Coding Helper
  • Byte 0
  • Bit 2 = Activate
Test Procedure
  • Turn off and lock vehicle
  • Open vehicle and sit inside with door closed
  • Open Windows
  • Start Car and idle for a few mins
  • Turn off car and exit leaving the windows open
  • Close door and lock
  • Wait for a few mins
  • Spray water or drum fingers over RLHS
*sunroof is never included in closing modification
Power Adjustable, Heated and Folding Mirrors - Folding Method
  3. 31347
  4. Adaption - 10
  5. Funk Spiegelanklappung Modus
  • by Convenience operation via remote control key = Fold on Lock
  • by look command via remote control key = Only fold on Long Key Press of Key Fob Button
Visual Representation Display of Parking Sensors (Pre-Facelift Vehicles Only)
  1. Control Module 10 - Park/Steer Assist
  3. 71679
  4. Coding - 07
  5. Long Coding Helper
  6. Byte 02
  7. Bit 0 = Activate
Daytime Running Lights Mode in Switch Position 0
  3. 31347
  4. Adaption - 10
  5. Daytime running lights - tagfahrlicht our in schalterstellung AUTO
  • Active = DRL Off in switch position 0
  • Not Active = DRL On in switch position 0
Daytime Running Lights Mode with Electronic Parking Brake Active
  3. 31347
  4. Adaption - 10
  5. Daytime running lights - tagfahrlicht Dauerfahrlicht being Handbremse abschalten
  • Active = DRL Off with electronic parking brake active
  • Not Active = DRL On with electronic parking brake active
Daytime Running Lights Brightness Level when Turn Signals Active (Bi Xenon and Full LED Pre-Facelift Vehicles Only)
  3. 31347
  4. Adaption - 10
  5. Leuchte2SL VLB10-dimming GH2
  6. Leuchte3SL VRB21-dimming GH3
  • 0 through to 127 where 0 = off and 127 = maximum brightness
Daytime Running Lights Brightness Level when Side Lights and Dipped Beams Active (Bi Xenon and Full LED Pre-Facelift Vehicles Only)
  3. 31347
  4. Adaption - 10
  5. Leuchte2SL VLB10-dimming AB2
  6. Leuchte3SL VRB21-dimming AB3
Rear Daytime Running Lights (LED)
  3. 31347
  4. Adaption - 10
  5. Leuchte23SL HLC10 light function D23
  6. Leuchte24SL HRA65 light function D24
  • select Daytime Running Light
Exterior Lighting MMI Menu
  3. 31347
  4. Adaption - 10
  5. Tagfahrlicht-Tagfahrlicht Aktivierung lurch BAP Oder Bedienfolge Moeglish
  6. Active
Door Warning Tone
  2. Adaption - 10
  3. Ignition active message actuator
  • No Display = No warning tone
  • Drivers Door = Warning tone with drivers door open
  • All Doors = Warning tone with any door open
