Audi A4 3.0tdi 2009 doesn't start
Tompanys
Sundsvall
Can someone tell me what they think is wrong with my car.
Thanks for letting me join.
I have a problem with my A4 3.0tdi I won't start or it is very close but stalls, it will run if i spray brake clean in to airbox.
Look at this two videos and say what you think,
as you see in one of the film it says that esp fault and parking brake fault and it set fault code on sens]or g28 crankshaft but I have change it.
This a full Autoscan of the car.
Monday,18,June,2018,08:55:23:00006
VCDS -- Windows Based VAG/VAS Emulator Running on Windows Vista x86
VCDS Version: 18.2.0.3
Data version: 20180212 DS287.0
www.Ross-Tech.com
VIN: WAUZZZ8K29A043749
Mileage: 161670km-100457mi Repair Order: auto scan
Chassis Type: 8K-AU48 (8T0)
Scan: 01 03 05 08 09 15 16 17 19 42 46 47 52 53 55 56 62 69 72
VIN: WAUZZZ8K29A043749 Mileage: 161670km-100457miles
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: Malfunction 0010
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
69-Trailer -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine (J623-CCWA) Labels: 059-907-401-V1.clb
Part No SW: 8K2 907 401 A HW: 8K1 907 401 A
Component: 3.0TDI EDC17 H01 0006
Revision: 15H01---
Coding: 010C002C180F0928
Shop #: WSC 38364 001 1048576
ASAM Dataset: EV_ECM30TDI0118K2907401A 001006
ROD: EV_ECM30TDI0118K2907401A.rod
VCID: 2B55B1AE4205361C9D-807E
3 Faults Found:
4698 - Function Restriction due to Faults in Other Modules
U1113 00 [036] - -
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 1
Mileage: 161678 km
Date: 2018.06.18
Time: 08:51:30
Engine speed: 963.00 /min
Normed load value: 84.7 %
Vehicle speed: 0 km/h
Coolant temperature: 30 C
Intake air temperature: 19 C
Ambient air pressure: 970 mbar
Voltage terminal 30: 11.840 V
Unlearning counter according OBD: 40
Crankshaft speed (RPM): 963.0 /min
Vehicle speed: 0.00 km/h
Cruise Control System: specified speed: 0.00 km/h
CCS status-Bits 0-7: 00101100
Cr Ctl st Shut Offirev-Bits 0-7: 00000000
Cr Ctl st Shut Offrev-Bits 0-7: 00000000
Cr C st Key 0-Bits 0-7: 00000000
4699 - Function Restriction due to Faults in Other Modules
U1113 00 [036] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Mileage: 161678 km
Date: 2018.06.18
Time: 08:51:30
4514 - Engine Speed Sensor (G28)
P0321 00 [101] - Implausible Signal
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Mileage: 161678 km
Date: 2018.06.18
Time: 08:51:29
Engine speed: 988.50 /min
Coolant temperature: 29 C
Voltage terminal 30: 11.380 V
Crankshaft speed (RPM): 988.5 /min
Epm st Sync: EPM_NO_SYNC
Vehicle voltage terminal 30: 11380 mV
Camshaft speed (RPM): 472.3 /min
Epm H Cr S st Sig Mode: WAITGAP
Epm n Eng Raw: 990.5 /min
Readiness: 0 0 0 0 0
Address 03: ABS Brakes (J104) Labels:. 8K0-907-379-V1.clb
Part No SW: 8K0 907 379 AD HW: 8K0 907 379 AD
Component: ESP8 quattro H04 0060
Revision: -------- Serial number: --------------
Coding: 1BC500
VCID: 7BF541EEFAE5669C4D-802E
2 Faults Found:
01314 - Engine Control Module
013 - Check DTC Memory - Intermittent
Freeze Frame:
Fault Status: 00101101
Fault Priority: 6
Fault Frequency: 1
Reset counter: 119
Mileage: 161678 km
Time Indication: 0
Date: 2018.06.18
Time: 08:51:30
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x0082
Hex Value: 0x000A
Hex Value: 0x4891
Hex Value: 0x00FF
00473 - Control Module for Elect. Park/Hand Brake (J540)
Freeze Frame:
Fault Status: 01101101
Fault Priority: 6
Fault Frequency: 1
Reset counter: 79
Mileage: 161678 km
Time Indication: 0
Date: 2018.06.18
Time: 08:51:31
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x6282
Hex Value: 0x0016
Hex Value: 0x0296
Hex Value: 0x00FF
Address 05: Acc/Start Auth. (J393) Labels:. 8K0-907-064-05.clb
Part No SW: 8K0 907 064 N HW: 8K0 907 064 N
Component: BCM2 1.1 H70 0134
Revision: 00002001
Coding: 030200
Shop #: WSC 06335 000 00000
VCID: 3B7581EEBA65A69C0D-806E
Subsystem 1 - Part No SW: 8T0 959 754 D HW: 8T0 959 754 D
Component: FBSAUDIB8 IDG H37 0060
Serial number: 0508000024339009
Subsystem 2 - Part No SW: 8K0 905 852 D HW: 8K0 905 852 D
Component: ELVAUDIB8 H35 0039
Serial number: 0208000023608001
No fault code found.
Address 08: Auto HVAC (J255) Labels: Redir Fail!
Part No SW: 8T1 820 043 AA HW: 8T1 820 043 AA
Component: KLIMA 1 ZONE H06 0140
Revision: A1000000 Serial number: 0110.06.081507
Coding: 36000000
VCID: 70EF66C2A3A315C4E8-8024
1 Fault Found:
00256 - A/C Pressure/Temperature Sensor (G395)
002 - Lower Limit Exceeded
Freeze Frame:
Fault Status: 01100010
Fault Priority: 2
Fault Frequency: 1
Reset counter: 79
Mileage: 161678 km
Time Indication: 0
Date: 2018.06.18
Time: 08:44:11
Freeze Frame:
Temperature: 18.0C
Temperature: 29.0C
Load: 0.0 %
Absolute Pres.: 0.8 bar
RPM: 240 /min
Speed: 0.0 km/h
Current: 0.000 A
Temperature: 22.0C
Address 09: Cent. Elect. (J519) Labels:. 8K0-907-063.clb
Part No SW: 8K0 907 063 D HW: 8K0 907 063 D
Component: BCM1 1.0 H22 0253
Revision: 05022001 Serial number: 00000000053540
Coding: 2600D0914034AF010001000300001D0D0F1C27080001010100 0000
VCID: 306FA6C2632355C4A8-8064
Subsystem 1 - Part No SW: 8K1 955 119 A HW: 8T1 955 119 Labels: 1KX-955-119.CLB
Component: WWS 290110 H06 0070
Serial number: SWF10010290428
Coding: 005914
Subsystem 2 - Part No SW: 8K0 955 559 HW: 8K0 955 559 Labels: 8K0-955-559.CLB
Component: RLS H04 0003
Serial number: 10148058
Coding: 025028
Subsystem 3 - Part No SW: 8K0 941 531 G HW: 8K0 941 531 G
Component: E1 - LDS H07 0070
Serial number: 00000000001106080518
The strangest thing if I crank it I get fuel pressure but when I try to jumpstart it with another car pulling I don't get any fuel pressure from the hpfp?
One more thing the fault codes esp, parking brake and crankshaft sensor G28 are only setting when the the rpm is a round 800Rpm and higher but I still have rpm signal to rev gauge
I have checked for metal shavings in the pump and there is nothing there.
I have sent the pump and injectors to be checked out by a specialist, but I think the rotor sender wheel for G28 is the problem here gonna take the gearbox out today and find out
