Thank you DV24v, i've just read your report. It's very helpful. Is your AUDI a 2019 model and does it have the silver housing over the battery to the right or is it just the battery like Paul’s RS4? Also, have you got the 19 inch space saver tyre and if so, could you provide the part number for that please? What I want to make sure is to get a 19 radius space saver with a wheel rim that has enough depth to clear the battery without anything getting in the way.
I’ve just taken these photos from the boot of the car. There is some space to the front of this area that shows another empty compartment where the jack can potentially be stored.
1) the cover and inflate kit underneath
2) just the inflate kit
3) with both of the above removed (to show how much space there is available).
4) Plastic tray cover
The photos below show the silver housing for the battery. I’m not sure why that is there (other cars like Paul’s don’t have it). It may be ok for the tyre to clear it if the tyre radius is big enough and if the wheel rim has enough depth so it doesn’t get in the way of the battery.
View attachment 195888 View attachment 195889
In the last photo i'm showing the cables that stick out and may get in the way of the wheel, but i'm guessing these can probably be bent to either go under the wheel or to the side.
The part numbers I’ve noted down are as follows:
Plastic cover (tray): 8W0.012.116.B
Silver battery housing cover: 8W0 915 172 B
Not sure if this is relevant but the Battery part no. is 8W0 915 105 A.
Thanks!
