Audi A4 roof problem....HELP!!
Breeze
Wicklow Ireland
Hi, can anybody help. I have an Audi A4 cabriolet 1.8T 2003. When trying to open the roof recently it suddenly stopped half way just as the boot lid had opened about an inch. I had to manually close the roof and I now cannot open the boot unless I use the key and the automatic roof switch won;t work at all. I closed the roof securely with the key that is supplied but the dash is flashing that the roof isn't secured. My mechanic reset the fault light but as soon as I started to drive it came straight back on. Any ideas?
did you use the roof key in the back seat aswell to lock it there ?
you need to open it manually all the way then close it manually
to reset it
or scan it on vcds to find the fault
this happened to me, it got stuck half way. I used the key to securly lock it as bez, has already said and no further problems e.g light on the dash
I dont know if there is a cabrio trouble shooting thread?
Thanks Bez & Bowen....I didn't open it fully I just closed it from the open position it was stuck in to get it home. I might try opening & closing it manually & see does that work. Thanks a million
Damn now i have a roof problem.
I go to open roof, gets half way but the roof storage lid thing didnt open? So i went to do it manually, as i have before. But when the roof is stored, the lid wont close? as if the roof is actually stopping it?!
At the moment the roof is up, but when i start the car the roof light comes up on the dash flashes a few times then disappears.
roof switch position sensor come adrift from its locator peg sounds to me located on the rh ram
