Rob_A8_3.0TDI
- Joined
- Aug 6, 2016
- Messages
- 6
- Reaction score
- 0
- Points
- 1
Hi guys,
New to the forum, had my A8 for about 6 months, purchased with the engine management light on. In an attempt to fix I have had the egr cleaned, turbo cleaned, full service filters & fluids changed etc, and have changed bank 1 manifold flap motor as it wasn't working.
Only code left now is the P3348 / 19804 fault which, after a lot of reading around, all seems to point towards the electronic turbo actuator or control unit next to the turbo. Now I believe if I replace this part it needs coding using a and I wanted to know if anyone knew a trusted specialist who could firstly try recoding my existing actuator to see if it's just an ecu issue or secondly replacing the actuator and coding in the new one.
Any further advice on this would be appreciated as I'm extremely fed up of countless trips to various garages with no luck.
I have a 2005 A8 3.0 tdi. The main symptoms are that the car goes into limp mode once the engine has warmed up. If I continue to accelerate hard (or go uphill) the glowplug light starts flashing too.
