I have an Audi S4 B8 3.0 TFSI – A few months ago developed a problem with the sports differential and I have been trying to resolve this for a few months now. Just wondering if anyone on here can point me in the right direction, as I am now at a loss.
I was driving along and on the dash appeared "sports differential fault" when I got back, I did a VCDS scan which returned:
Address 22: AWD (J492) Labels: 8K0-907-163.clb
Part No SW: 8K0 907 163 HW: 8K0 907 163
Component: 4 Wheel Drive H09 0004
Serial number: 002107090001029
ASAM Dataset: EV_AllWheelDiffeQSPCAN 003007
ROD: EV_AllWheelDiffeQSPCAN.rod
VCID: 6D8637B1CD119403545-8038
1 Fault Found:
0325 - Internal Control Module Memory Check Sum Error
B2000 00 [137] - -
[SG Defekt DTC_QCU_DEFEKT]
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 1
Fault Frequency: 1
Mileage: 112100 km
Date: 2021.03.27
Time: 13:38:26
I replaced the module with another controller from eBay (same codes and looked identical) which gave a different error code.
Serial number: 001906090001019
2 Faults Found:
0312 - invalid data record
B2005 00 [001] - -
[Ungültiger Datensatz DTC_DAT_INVALID]
Not Confirmed - Tested Since Memory Clear
0204 - Control Module Does Not Match Vehicle
B2006 00 [001] - -
[QSP - Steuergerät VIN gültig: aber abweichend DTC_CAN_BCM3_WRONG_VIN]
I have had an auto electrician have a go at programming this to change the VIN on the module, but it comes back with the same errors.
Does anyone know where I can go next with this? As every time I start the car it beeps “sports differential fault” which is a constant reminder to fix it.
1 Fault Found:
B2000 00 [137] - -
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Mileage: 112100 km
Date: 2021.03.27
Time: 13:38:26
2 Faults Found:
B2005 00 [001] - -
B2006 00 [001] - -
