France occy
- Joined
- Jan 31, 2015
- Messages
- 1
- Reaction score
- 0
- Points
- 1
Good day to all
I'm new to this forum
I've read many threads prior to posting in the past and they've been very helpful
Now .
I have a 2010 audi q5 with bixenon decided to try the afs adaptive light retrofit ,,
I'm having a bit of problem with coding the module
can anyonevhelp me those are the fault codes I'm getting
I did the pin outs already got the headlights and the AFS module
I have a new set of headlights
Have a new afs module
I have the vag com cable
:8H0907357C from audi a5 2012
Did the pin outs as per this write up
http://www.audiworld.com/forums/vag...4-rs4-bi-xenon-bi-xenon-afs-retrofit-2822341/
But it seems like I cannot code the module no matter what I try
It's not accepting the coding
I go to adptation and module not coded
When I go to xenon range
I don't see the option for on/off/on as before
Tuesday,03,February,2015,20:21:35:65217
VCDS Version: Release 12.12.0
Address 55: Xenon Range Labels: 8T0-907-357.clb
Control Module Part Number: 8H0 907 357 C HW: 8H0 907 357 C
Component and/or Version: AFS 1 H01 0040
Software Coding: 0000255
Work Shop Code: WSC 06324 000 00000
Additional Info: ----------- AFS-Modul links ----------- AFS-Modul rechts
VCID: 32610288ADD1A08E527-8067
2 Faults Found:
01042 - Control Module; Not Coded
000 - - - MIL ON
Freeze Frame:
Fault Status: 11100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 40
Mileage: 127553 km
Time Indication: 0
Date: 2015.02.03
Time: 20:17:53
01539 - Headlights Not Adjusted
005 - No or Incorrect Basic Setting / Adaptation - MIL ON
Freeze Frame:
Fault Status: 11100101
Fault Priority: 2
Fault Frequency: 1
Reset counter: 40
Mileage: 127553 km
Time Indication: 0
Date: 2015.02.03
Time: 20:17:53
Now .
2 Faults Found:
000 - - - MIL ON
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 40
Mileage: 127553 km
Time Indication: 0
Date: 2015.02.03
Time: 20:17:53
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 40
Mileage: 127553 km
Time Indication: 0
Date: 2015.02.03
Time: 20:17:53
