Hi guys,
I've got a 2006 Audi q7 which I'm struggling with. It's battery had died, and ever since I've had it started back up (running for a few days now) and the battery is showing at 100% battery charge.
The issues I am having are that my parking sensors more my reverse camera works anymore. The display no longer shows my camera / parking sensors.
I've done a scan and the following is what I see.....Any help is appreciated!!
Wednesday,17,October,2018,17:34:48:20893
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 18.9.0.2 (x64)
Data version: 20180927 DS296.0
www.Ross-Tech.com
VIN: WAUZZZ4L97D057531 License Plate: DK56XTT
Mileage: 147550km-91683mi Repair Order:
Chassis Type: 4L (4L0)
Scan: 01 02 03 05 06 07 08 09 0E 13 15 16 17 18 19 34 36 37 3C 42
46 47 4F 52 55 56 61 62 65 67 6C 6D 6F 72 76 77
VIN: WAUZZZ4L97D057531 Mileage: 147550km-91683miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
05-Acc/Start Auth. -- Status: Malfunction 0010
06-Seat Mem. Pass -- Status: OK 0000
07-Control Head -- Status: Malfunction 0010
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
0E-Media Player 1 -- Status: OK 0000
13-Auto Dist. Reg -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
18-Aux. Heat -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
34-Level Control -- Status: Malfunction 0010
36-Seat Mem. Drvr -- Status: Malfunction 0010
37-Navigation -- Status: Malfunction 0010
3C-Lane Change -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
47-Sound System -- Status: Cannot be reached 1100
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
61-Battery Regul. -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
65-Tire Pressure -- Status: Malfunction 0010
67-Voice Control -- Status: OK 0000
6C-Back-up Cam. -- Status: Malfunction 0010
6D-Trunk Elect. -- Status: OK 0000
6F-Centr. Conv. II -- Status: OK 0000
72-Door, Rear Right -- Status: Malfunction 0010
76-Park Assist -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine Labels: 059-907-401-ASB.clb
Part No SW: 4L0 910 401 M HW: 4L0 907 401
Component: 3.0L V6TDI A001AG 0030
Revision: --H03--- Serial number:
Coding: 0011775
Shop #: WSC 31414 790 00001
VCID: 2C5CD39E8F5AAA2A59-8078
2 Faults Found:
004120 - Intake Manifold Runner (Bank 2)
P1018 - 001 - Lower limit not reached - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 0
Fault Frequency: 38
Reset counter: 255
Mileage: 147137 km
Time Indication: 0
Date: 2018.10.04
Time: 23:26:49
Freeze Frame:
RPM: 945 /min
Torque: 62.4 Nm
Speed: 0.0 km/h
Voltage: 13.91 V
Duty Cycle: 80.9 %
Duty Cycle: 88.8 %
Duty Cycle: 80.9 %
001025 - EGR System
P0401 - 002 - Insufficient Flow - Intermittent
Freeze Frame:
Fault Status: 00110010
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 147230 km
Time Indication: 0
Date: 2018.10.06
Time: 01:13:54
Freeze Frame:
RPM: 1827 /min
Torque: 124.8 Nm
Speed: 93.0 km/h
Duty Cycle: 55.8 %
Duty Cycle: 20.9 %
(no units): 0.0
Duty Cycle: 11.0 %
Readiness: 0 1 0 0 0
Address 02: Auto Trans Labels: 09D-927-750.clb
Part No SW: 09D 927 750 FK HW: 09D 927 750 FK
Component: AL 750 6A 0940
Revision: 00H52000 Serial number:
Coding: 0000504
VCID: 7CFC23DE3FBAFAAA89-8028
No fault code found.
Address 03: ABS Brakes Labels:. 4L0-910-517-V1.clb
Part No SW: 4L0 910 517 A HW: 4L0 614 517 A
Component: ESP ALLRAD MK25E1 0130
Revision: 00H21001
Coding: 0562321
Shop #: WSC 00641 210 88433
VCID: 28542F8E9BA2860ABD-807C
Address 05: Acc/Start Auth. Labels:. 4F0-910-852.clb
Part No SW: 4F0 910 852 HW: 4F0 905 852 B
Component: FBSAUDIC6 ELV H31 0240
Revision: 07020801 Serial number: 10601100546125
Coding: 0000151
Shop #: WSC 31414 210 01865
VCID: 63CE78A2A2042552A8-8036
Subsystem 1 - Part No: 4F0 910 131 G
Component: FBSAUDIC6 EZS H45 0080
Subsystem 2 - Part No: 4F0 910 335
Component: FBSAUDIC6 KSG H27 0080
Subsystem 3 - Part No: 4F0 910 220 K
Component: FBSAUDIC6 IDG H01 0060
1 Fault Found:
02764 - Access/Start Authorization Switch (E408)
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 40
Time Indication: 0
Address 06: Seat Mem. Pass Labels: None
Part No SW: 4F0 910 760 HW: 4L0 959 760
Component: Sitzmemory BFS H01 0100
Revision: 00000000 Serial number: 00000000896401
Coding: 0078944
VCID: 61C272AAB8183742BA-8034
Address 07: Control Head Labels: 4L0-910-7xx-07-H.clb
Part No SW: 4L0 910 732 T HW: 4E0 035 729 A
Component: Interfacebox H43 5150
Revision: 00000000 Serial number: 387J/067526482
Coding: 0000000
Shop #: WSC 00000 000 00000
VCID: 3A70E5C6750E049ADB-806E
Subsystem 1 - Part No: 4L0 910 609
Component: E0380 BedienteilH01 0060
Subsystem 2 - Serial number: 00000001140939
Subsystem 3 - Serial number: 0104.08.080000000100010916ÿ
Subsystem 4 - Serial number: 010916ÿ
4 Faults Found:
00003 - Control Module
005 - No or Incorrect Basic Setting / Adaptation
Freeze Frame:
Fault Status: 01100101
Fault Priority: 5
Fault Frequency: 1
Reset counter: 17
Mileage: 146337 km
Time Indication: 0
Date: 2018.06.22
Time: 10:27:55
00384 - Optical Databus
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 5
Fault Frequency: 246
Reset counter: 109
Time Indication: 15
01042 - Control Module; Not Coded
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 7
Fault Frequency: 1
Reset counter: 255
Time Indication: 15
00446 - Function Limitation due to Under-Voltage
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 7
Fault Frequency: 1
Reset counter: 59
Mileage: 146359 km
Time Indication: 0
Date: 2018.07.14
Time: 17:17:16
Address 08: Auto HVAC Labels: None
Part No SW: 4L0 910 043 HW: 4L0 820 043 F
Component: KLIMABETAETIGUNGH05 0060
Revision: 00---011 Serial number: 00000000078564
Coding: 0001046
1 Fault Found:
02380 - Positioning Motor for Right Side Vent (V300)
003 - Mechanical Failure
Freeze Frame:
Fault Status: 01100011
Fault Priority: 3
Fault Frequency: 163
Reset counter: 76
Mileage: 147134 km
Time Indication: 0
Date: 2018.10.04
Time: 22:51:44
Freeze Frame:
Voltage: 12.00 V
Temperature: 26.0°C
(no units): 51.0
(no units): 86.0
Temperature: 23.0°C
Address 09: Cent. Elect. Labels: 4F0-910-279.lbl
Part No SW: 4F0 910 279 J HW: 4F0 907 279 A
Component: ILM Fahrer H17 0240
Revision: 00000000 Serial number: 4F0907279
Coding: 0113121
VCID: 3064C7EEA372CECA65-8064
Subsystem 1 - Part No: 4L2 910 113 Labels: 1KX-955-119.CLB
Component: Wischer AU716 H08 0080
Coding: 00064792
Shop #: WSC 31414
Subsystem 2 - Part No: 4E0 910 557 A Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH13 0090
Coding: 00150059
Shop #: WSC 31414
2 Faults Found:
02745 - Bulb for Daytime Running Light; Left
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 2
Fault Frequency: 1
Reset counter: 76
Mileage: 147548 km
Time Indication: 0
Date: 2018.10.11
Time: 16:47:00
01498 - Bulb for Parking Lamps; Right (M3)
011 - Open Circuit
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 76
Mileage: 147548 km
Time Indication: 0
Date: 2018.10.11
Time: 16:47:00
Address 0E: Media Player 1 Labels: 4E0-910-111.lbl
Part No SW: 4L0 910 111 A HW: 4L0 035 111
Component: CD-Changer H41 0100
Revision: 00000000 Serial number: AUZ5ZBF3054241
VCID: 1E380956C9E648BAC7-804A
Address 13: Auto Dist. Reg Labels: None
Part No SW: 4L0 910 561 HW: 4L0 907 561
Component: ABSTANDSREGELUNGH05 0120
Revision: -------- Serial number: 00000000000000
Coding: 0031158
VCID: 66C861B65136507A4F-8032
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 114
Mileage: 147335 km
Time Indication: 0
Date: 2018.10.08
Time: 02:40:20
Freeze Frame:
Temperature: 13.0°C
Voltage: 9.09 V
Bin. Bits: 01000
Hex Value: 0x0346
Hex Value: 0x0003
Speed: 0.0 km/h
Lateral Accel.: 0.00 m/s^2
Address 15: Airbags Labels: 4L0-910-655.lbl
Part No SW: 4L0 910 655 B HW: 4L0 959 655
Component: 30 AIRBAG AUDI8RH38 0120
Revision: 05H38000 Serial number: 0037GD06UPES
Coding: 0013104
Subsystem 1 - Serial number: 6332QSME1774391DK
Subsystem 2 - Serial number: 6342QSME18171E07F
Subsystem 3 - Serial number: 6352QSME151078111
Subsystem 4 - Serial number: 6362QSME1511144FA
Subsystem 5 - Serial number: 63734SME15094425V
Subsystem 6 - Serial number: 63834SME151B4821Z
Address 16: Steering wheel Labels: 4F0-910-549.lbl
Part No SW: 4F0 910 549 HW: 4F0 953 549 A
Component: Lenksäulenmodul H08 0230
Revision: 00H08000 Serial number: 90026062570116
Coding: 0112152
Subsystem 1 - Part No: XXXXXXXXXXX
Component: Lenkradmodul H07 0090
Address 17: Instruments Labels: 4L0-910-xxx-17.lbl
Part No SW: 4F0 910 930 C HW: 4L0 920 980 A
Component: KOMBIINSTR. M73 H17 0170
Revision: 00400000 Serial number: 5HD32L186
Coding: 2801443
Shop #: WSC 12345 067 57207
VCID: 234E38A2E2846552E8-8076
Address 18: Aux. Heat Labels: None
Part No SW: 4L0 910 105 HW: 4L0 815 071 C
Component: Heizgeraet H07 0060
Revision: 0000000E Serial number: 00000009011043
Coding: 0000002
VCID: 60C477AEB3123E4AB5-8034
Address 19: CAN Gateway Labels:. 4L0-910-468.clb
Part No SW: 4L0 910 468 HW: 4L0 907 468 A
Component: J533__Gateway H06 0040
Revision: 00H06000 Serial number: 0800D06923813A
Coding: F5DFFF7F357202
Shop #: WSC 00641 210 91756
VCID: 6CDC139E4FDA6A2A19-8038
2 Faults Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 5
Reset counter: 109
Mileage: 147134 km
Time Indication: 0
Date: 2018.10.04
Time: 22:53:52
00463 - Control Module for Digital Sound Package (J525)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 3
Fault Frequency: 1
Reset counter: 69
Mileage: 147393 km
Time Indication: 0
Date: 2018.10.09
Time: 03:17:52
Address 34: Level Control Labels: 4L0-910-553.lbl
Part No SW: 4L0 910 553 F HW: 4L0 907 553
Component: LUFTFDR.-CDC H03 7750
Revision: --H03001 Serial number: 15.1528-0095.2
Coding: 0015510
Shop #: WSC 00272 210 89558
VCID: 2D5ADE9AB440A3224E-8078
2 Faults Found:
01577 - Turn-Off due to Over-Temp
001 - Upper Limit Exceeded - Intermittent
Freeze Frame:
Fault Priority: 6
Fault Frequency: 31
Reset counter: 168
Mileage: 147147 km
Time Indication: 0
Date: 2018.10.05
Time: 01:04:11
Freeze Frame:
Error Code: 68
03004 - Load Level Button (E539)
012 - Electrical Fault in Circuit - Intermittent
Freeze Frame:
Fault Status: 00101100
Fault Priority: 4
Fault Frequency: 2
Reset counter: 168
Mileage: 147388 km
Time Indication: 0
Date: 2018.10.09
Time: 01:58:18
Freeze Frame:
Error Code: 156
Address 36: Seat Mem. Drvr Labels: None
Component: Sitzmemory FS H01 0100
Coding: 0074858
1 Fault Found:
01447 - Sensor for Driver Seat; Height Adjust (G231)
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 76
Mileage: 147132 km
Time Indication: 0
Date: 2018.10.04
Time: 22:52:28
Address 37: Navigation Labels: 4E0-910-88x-37.lbl
Part No SW: 4E0 910 887 Q HW: 4E0 919 887 D
Component: MNS ECE H48 0850
Revision: 00000000 Serial number: 399JZ067540550
Shop #: WSC 00641 210 00243
VCID: 3B7EE0C27A343D92C0-806E
1 Fault Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 2
Reset counter: 80
Mileage: 146359 km
Time Indication: 0
Date: 2018.07.14
Time: 17:17:30
Address 3C: Lane Change Labels: None
Part No SW: 4L0 910 566 A HW: 4L0 907 566 A
Component: J0769_SWA_MasterH06 0060
Revision: 00H06000 Serial number: 6PZ 009 014-00
Coding: 0001101
Subsystem 1 - Part No: 4L0 910 568 A
Component: J0770_SWA_Slave_H05 0060
Subsystem 2 - Serial number: 6PZ 009 014-20
Subsystem 3 - Serial number: 3F11.10.0600H0500000010198ÿ
Subsystem 4 - Serial number: 010198ÿ
Address 42: Door Elect, Driver Labels: 4L0-910-793-42.lbl
Part No SW: 4L0 910 793 B HW: 4L0 959 793 B
Component: TSG FA H12 0130
Revision: 00-00000
Coding: 0019163
VCID: 2F66C492BE4CD1327C-807A
1 Fault Found:
02126 - Central Locking Button; Exterior Door Handle
Freeze Frame:
Fault Status: 01101000
Fault Priority: 3
Fault Frequency: 27
Reset counter: 71
Mileage: 147318 km
Time Indication: 0
Date: 2018.10.07
Time: 02:47:09
Address 46: Central Conv. Labels:. 4L0-910-289.lbl
Part No SW: 4L0 910 289 D HW: 4L0 907 289 A
Component: Komfortgeraet H05 0020
Revision: 0020 --- Serial number: 01021352220000
Coding: 7610619
VCID: 3162C2EAA878C7C26A-8064
Subsystem 1 - Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H03 1301
Subsystem 2 - Part No: 4F0 910 177
Component: Innenraumueberw.H01 0020
Address 47: Sound System
Cannot be reached
Address 4F: Centr. Electr. II Labels: 4F0-910-280.lbl
Part No SW: 4F0 910 280 HW: 4F0 907 280 E
Component: ILM Beifahrer H10 0080
Revision: Serial number: 00000000015459
Coding: 0011101
VCID: 5EB84956896608BA87-800A
Address 52: Door Elect, Pass. Labels: 4L0-910-793-52.lbl
Part No SW: 4L0 910 793 B HW: 4L0 959 792 B
Component: TSG BF H12 0130
Revision: 00-00000
Coding: 0019163
Address 55: Headlight Range Labels: 4F0-910-357.lbl
Part No SW: 4F0 910 357 F HW: 4F0 907 357 F
Component: AFS 1 H01 0020
Revision: 00000001 Serial number:
Coding: 0000022
VCID: 29522A8A80A8BF02A2-807C
Subsystem 1 - Part No: 7L6 941 329 A
Component: AFS-Modul links H06 0002
Subsystem 2 - Part No: 7L6 941 329 A
Component: AFS-Modul rechtsH06 0002
Address 56: Radio Labels: 4E0-910-541.lbl
Part No SW: 4E0 910 541 Q HW: 4E0 035 541 P
Component: TUNER EU/US/RDW H42 0620
Revision: 00000000 Serial number: 388J+067561717
Coding: 0000001
VCID: 2E58D996B946D83A77-807A
2 Faults Found:
00532 - Supply Voltage B+
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 116
Mileage: 146359 km
Time Indication: 0
Date: 2018.07.14
Time: 17:18:01
Freeze Frame:
Fault Priority: 7
Fault Frequency: 197
Reset counter: 116
Mileage: 146359 km
Time Indication: 0
Date: 2018.07.14
Time: 17:17:22
Address 61: Battery Regul. Labels: 4F0-910-181.lbl
Part No SW: 4L0 910 181 HW: 4L0 915 181
Component: J0644 BEM H12 0530
Revision: -------- Serial number: 00000000049459
VCID: 64CC7BBEA70A226A51-8030
Subsystem 1 - Part No: 4F0 915 105 D
Component: von VA0 2610121199
Coding: 344630393135313035442056413032363130313231313939
2 Faults Found:
03041 - Energy Management Active
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 7
Fault Frequency: 35
Reset counter: 255
Mileage: 146359 km
Time Indication: 0
Date: 2018.07.08
Time: 12:38:25
02256 - Quiescent Current
Freeze Frame:
Fault Status: 00110001
Fault Priority: 7
Fault Frequency: 9
Reset counter: 82
Mileage: 147011 km
Time Indication: 0
Date: 2018.09.21
Time: 00:53:58
Address 62: Door, Rear Left Labels: 4L0-910-795.lbl
Part No SW: 4L0 910 795 B HW: 4L0 959 795 B
Component: TSG HL H21 0050
Coding: 0018442
Address 65: Tire Pressure Labels: 4F0-910-273-HI.lbl
Part No SW: 4F0 910 273 C HW: 4F0 907 273 A
Component: Reifendruck 3 H05 0100
Revision: 00050100 Serial number: 00000900018242
Coding: 0222424
4 Faults Found:
01467 - Front Left Tire Pressure Sensor (G222)
004 - No Signal/Communication - MIL ON
Freeze Frame:
Fault Status: 11100100
Fault Priority: 3
Fault Frequency: 1
Reset counter: 17
Mileage: 146343 km
Time Indication: 0
Date: 2018.06.22
Time: 11:06:40
Freeze Frame:
(no units): 46.0
Voltage: 14.10 V
(no units): 46.0
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
01468 - Front Right Tire Pressure Sensor (G223)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 17
Mileage: 146343 km
Time Indication: 0
Date: 2018.06.22
Time: 11:06:40
Freeze Frame:
(no units): 46.0
Voltage: 14.10 V
(no units): 49.0
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
01469 - Rear Left Tire Pressure Sensor (G224)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 17
Mileage: 146343 km
Time Indication: 0
Date: 2018.06.22
Time: 11:06:40
Freeze Frame:
(no units): 46.0
Voltage: 14.10 V
(no units): 52.0
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
01470 - Rear Right Tire Pressure Sensor (G225)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 17
Mileage: 146343 km
Time Indication: 0
Date: 2018.06.22
Time: 11:06:40
Freeze Frame:
(no units): 46.0
Voltage: 14.10 V
(no units): 55.0
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
Address 67: Voice Control Labels: 4E0-910-75x-67.lbl
Part No SW: 4E0 910 754 S HW: 4E0 035 753 A
Component: SDS 3502 UK H45 0630
Revision: 00000000 Serial number: 00000610050117
Shop #: WSC 12336 024 394758
VCID: 3668F1F64116E0FA3F-8062
Address 6C: Back-up Cam. Labels: 4L0-910-441.clb
Part No SW: 4L0 910 441 A HW: 4L0 907 441 A
Component: J772__Rearview 0050
Revision: --H12--- Serial number: 525PA8-J6943EY
Coding: 1021001
VCID: 244C3BBEE78A626A91-8070
1 Fault Found:
03006 - Back-up Camera System not calibrated
000 - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 76
Time Indication: 0
Freeze Frame:
Invalid
Invalid
Invalid
Address 6D: Trunk Elect. Labels: None
Part No SW: 4L0 910 945 HW: 4L0 827 851 B
Component: ValeoHeckdeckel H21 0280
Revision: --H21001 Serial number: E5030000B
Shop #: WSC 98765 666 38354
Subsystem 1 - Part No: 4L0 910 946
Subsystem 2 - Serial number: E5030100B
Subsystem 3 - Serial number: RD18.10.06--H21001001A0084ÿ
Subsystem 4 - Serial number: 1A0084ÿ
Address 6F: Centr. Conv. II Labels:. 4L0-910-290.lbl
Part No SW: 4L0 910 290 A HW: 4L0 907 290 A
Component: ILM HINTEN 2 H05 0060
Revision: AAH05061 Serial number: 002082422-----
Coding: 0003587
VCID: 264821B691B6907A8F-8072
Subsystem 1 - Part No: 4L0 910 591
Component: J_245_EE15_SKB09H10 0180
Subsystem 2 - Part No: 4L0 910 591
Component: J_394_EE15_SKB09H10 0180
Subsystem 3 - Part No: 4L0 910 591
Component: J_392_EE15_SKB09H10 0180
Address 72: Door, Rear Right Labels: 4L0-910-795.lbl
Part No SW: 4L0 910 795 B HW: 4L0 959 794 B
Component: TSG HR H21 0050
Coding: 0018442
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 3
Reset counter: 42
Time Indication: 0
Address 76: Park Assist Labels: 4Fx-910-283.lbl
Part No SW: 4F0 910 283 G HW: 4F0 919 283 G
Component: Parkhilfe 8-Kan H12 0060
Revision: 00H12000 Serial number: 06330628502951
Coding: 0221146
Address 77: Telephone Labels: 4E0-910-336.lbl
Part No SW: 4E0 910 336 M HW: 4E0 862 335
Component: Handyvorb2 H16 1130
Revision: 00000000 Serial number: 00000007639070
Coding: 0010920
End-------------------------(Elapsed Time: 03:31)--------------------------
www.Ross-Tech.com
Coding: 0011775
2 Faults Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 38
Reset counter: 255
Mileage: 147137 km
Time Indication: 0
Date: 2018.10.04
Time: 23:26:49
Freeze Frame:
RPM: 945 /min
Torque: 62.4 Nm
Speed: 0.0 km/h
Voltage: 13.91 V
Duty Cycle: 80.9 %
Duty Cycle: 88.8 %
Duty Cycle: 80.9 %
001025 - EGR System
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 147230 km
Time Indication: 0
Date: 2018.10.06
Time: 01:13:54
Freeze Frame:
RPM: 1827 /min
Torque: 124.8 Nm
Speed: 93.0 km/h
Duty Cycle: 55.8 %
Duty Cycle: 20.9 %
(no units): 0.0
Duty Cycle: 11.0 %
Coding: 0000504
Revision: 00H21001
Coding: 0562321
Coding: 0000151
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 40
Time Indication: 0
Coding: 0078944
Coding: 0000000
4 Faults Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 17
Mileage: 146337 km
Time Indication: 0
Date: 2018.06.22
Time: 10:27:55
Freeze Frame:
Fault Priority: 5
Reset counter: 109
Time Indication: 15
000 - -
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 255
Time Indication: 15
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 59
Mileage: 146359 km
Time Indication: 0
Date: 2018.07.14
Time: 17:17:16
Coding: 0001046
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Reset counter: 76
Mileage: 147134 km
Time Indication: 0
Date: 2018.10.04
Time: 22:51:44
Freeze Frame:
Voltage: 12.00 V
Temperature: 26.0°C
(no units): 51.0
(no units): 86.0
Temperature: 23.0°C
Coding: 0113121
Coding: 00064792
Shop #: WSC 31414
Coding: 00150059
Shop #: WSC 31414
2 Faults Found:
011 - Open Circuit
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 76
Mileage: 147548 km
Time Indication: 0
Date: 2018.10.11
Time: 16:47:00
011 - Open Circuit
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 76
Mileage: 147548 km
Time Indication: 0
Date: 2018.10.11
Time: 16:47:00
Coding: 0031158
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 114
Mileage: 147335 km
Time Indication: 0
Date: 2018.10.08
Time: 02:40:20
Freeze Frame:
Temperature: 13.0°C
Voltage: 9.09 V
Bin. Bits: 01000
Hex Value: 0x0346
Hex Value: 0x0003
Speed: 0.0 km/h
Coding: 0013104
Coding: 0112152
Coding: 2801443
Coding: 0000002
2 Faults Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 5
Reset counter: 109
Mileage: 147134 km
Time Indication: 0
Date: 2018.10.04
Time: 22:53:52
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 69
Mileage: 147393 km
Time Indication: 0
Date: 2018.10.09
Time: 03:17:52
Coding: 0015510
2 Faults Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 31
Reset counter: 168
Mileage: 147147 km
Time Indication: 0
Date: 2018.10.05
Time: 01:04:11
Freeze Frame:
Error Code: 68
Freeze Frame:
Fault Priority: 4
Fault Frequency: 2
Reset counter: 168
Mileage: 147388 km
Time Indication: 0
Date: 2018.10.09
Time: 01:58:18
Freeze Frame:
Error Code: 156
Coding: 0074858
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 76
Mileage: 147132 km
Time Indication: 0
Date: 2018.10.04
Time: 22:52:28
1 Fault Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 2
Reset counter: 80
Mileage: 146359 km
Time Indication: 0
Date: 2018.07.14
Time: 17:17:30
Coding: 0001101
Revision: 00-00000
Coding: 0019163
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 27
Reset counter: 71
Mileage: 147318 km
Time Indication: 0
Date: 2018.10.07
Time: 02:47:09
Coding: 7610619
Cannot be reached
Coding: 0011101
Revision: 00-00000
Coding: 0019163
Coding: 0000022
Coding: 0000001
2 Faults Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 116
Mileage: 146359 km
Time Indication: 0
Date: 2018.07.14
Time: 17:18:01
Freeze Frame:
Fault Priority: 7
Reset counter: 116
Mileage: 146359 km
Time Indication: 0
Date: 2018.07.14
Time: 17:17:22
2 Faults Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 35
Reset counter: 255
Mileage: 146359 km
Time Indication: 0
Date: 2018.07.08
Time: 12:38:25
Freeze Frame:
Fault Priority: 7
Fault Frequency: 9
Reset counter: 82
Mileage: 147011 km
Time Indication: 0
Date: 2018.09.21
Time: 00:53:58
Coding: 0018442
Coding: 0222424
4 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 17
Mileage: 146343 km
Time Indication: 0
Date: 2018.06.22
Time: 11:06:40
Freeze Frame:
(no units): 46.0
Voltage: 14.10 V
(no units): 46.0
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 17
Mileage: 146343 km
Time Indication: 0
Date: 2018.06.22
Time: 11:06:40
Freeze Frame:
(no units): 46.0
Voltage: 14.10 V
(no units): 49.0
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 17
Mileage: 146343 km
Time Indication: 0
Date: 2018.06.22
Time: 11:06:40
Freeze Frame:
(no units): 46.0
Voltage: 14.10 V
(no units): 52.0
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 17
Mileage: 146343 km
Time Indication: 0
Date: 2018.06.22
Time: 11:06:40
Freeze Frame:
(no units): 46.0
Voltage: 14.10 V
(no units): 55.0
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
Coding: 1021001
1 Fault Found:
000 - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 76
Time Indication: 0
Freeze Frame:
Invalid
Invalid
Invalid
Coding: 0003587
Coding: 0018442
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 3
Reset counter: 42
Time Indication: 0
Coding: 0221146
Coding: 0010920
