All done guys thank you very much I appreciate your help so much. I switched both left and right headlights to flat beam by switching the lever, I also made a video which I will post
here so you can have a look.
Also for changing the fog lights from right to the left is not that difficult you just have to follow the following instructions:
1) Take the left taillight off which you access from the boot of the car by taking the 4 nuts off the bolts from the inside of the boot
2) Pull the plug off from the rear of the left taillight and also take the white plastic off from the main taillight which will expose the bulbs and you will notice that there is no bulb on the top position neither place for one to pass through the taillight so you will have to make a hole on the rear of the taillight. Its not difficult I just got my battery drill will a small drill bit and started going around until I made the hole big enough.
3) Add a bulb and put the taillight back in place.
4) Splice the third cable from the right taillight (there are number on the plug that goes on the rear of the taillight) and connect it to left taillight on the third position on the plug. I just put the cable inside the plug by opening it and then closing it.
5) Final tip is you can pass the cable along below where the safety triangles are. Just take the 4 torx screws from the tailboot. Also take the screws
These pictures might help:
This is the compartment that you need to open to access the taillight, it exists on both sides of the car.
This is the hook that I believe is used to tie things up in the boot you need to remove the 2 bolts holding it and remove it. There are 4 of these hooks in the boot you only need to remove the rear 2.
These are the torx screws I was talking about, there are 4 of them you need to remove.
This is the left side and you can see the blue cable I installed which runs under the safety triangle and looks neat.
And here is the final outcome with the left fog light on instead of the right one as I used the bulb from the right to put on the left.
If you want both sides to light up when you turn on your fog lights just install a light bulb on both sides, simple as that.
The whole fog light conversion took me 1 hour including finding out what I needed to do.
