Audi S3 clutch??
Bigandbald
Basingstoke
Morning all,
once I leave my car for a few hours or more, usually overnight I come and drive it and the clutch pedal has sunk down half way. Now if I don't move it the biting point will be right at the bottom, so I pull it back up and it is back to normal!
any ideas guys???
Oh well new gearbox it is then as mine crunches when changing up into third quickly or down to second.
Whys it a gearbox out to bleed it? You can bleed it off the master cylinder cant you?
dualmass fried i think.
Had the same, down to the bottom, pulled it up, made it just to home, and it was on the bottom again.
there was a lot of play on the flywheel what caused the slave cilinder to burn.
Ok thanks chaps, I think I'll have a go at bleeding it. It only sinks down about 1-2inchs.
fingers crossed all works out ok?
