how do you permanently disable it - instruction manual is useless so I just do manually every trip which is daft
shame car is great otherwise
I think its stupid - why should I be forced to have a feature I don't want
I actually think its dangerous - come to a split second stop on a roundabout - moronic s/s cuts in, car behind stoves into the back of your car, brilliant!
when I test drove the manual and pull out of a side road, it cut in and I was sat across the road waiting to be t-boned
Has anyone any experience of start/stop in the TDI? Just wondering whar its like.
The other trick you can employ while waiting at junctions and roundabouts -
If you're at a junction or roundabout and want to prepare for a quick getaway, but the S/S has already stopped the engine:
Simply "tug" the steering wheel (sharp turn either direction) briefly - the car will restart, leaving you with a running engine, ready for a quick getaway!
The the s-tronic you can contol if the start stop kicks in with how sensitive you are on the brake pedal when coming to a stop.
The car can apply the auto brake first but does require a little further pressure on the brake pedal to get the start stop to kick in. Just try experimenting a bit.
It's actually quite well setup IMHO.
When using ACC the car will go into start stop mode after 3 seconds of sitting stationary but will restart automatically when the car in front pulls away, then you just pull the ACC lever to resume and it pulls away
I just turn it off when i start the car, if i hit some serious traffic on the m25 i might turn it back on again just for the fuel saving. But generally its off.
Don't really like the idea of the engine being started and stopped multiple times in a journey. Cant been too healthy for the turbo.
I wonder if the damn S/S can result in a damage to the engine and its component. My thoughts:
1) The battery: every time the engine is cut off, all other accessories remain on. So the battery is drained and every time the engine is restarted there is a peak of power demand to the battery. I suspect the battery is over-stressed.
2) The starter motor: When I was a child my grandma Mini Cooper (the original one) suffered several time from starter motor failures. Hope the technology advanced a lot for being reliable with so much starts during the life of the car.
3) The sparking plugs, the catalytic converter : Every time the engine is restarted I suppose that uncombusted fuel goes on the sparking plugs and in the catalytic converter. How these devices are affected by the S/S?
4) The turbocharger: Some years ago a friend of mine with a Golf IV GTI diesel, before cutting of the engine kept it revving at minimum for one minute to allow the cooling of the turbocharger. With the S/S how the turbocharger could be cooled? Maybe, having the S3 an electric engine coolant pump, it remains on during S/S sessions?
I suspect that a economic/ecologic directive could affect the life and reliability of the car and its components. I would like to know the opinion of a car expert...
Why not? I don't think the turbo is involved...
It's fine - what in specific are you thinking of that would make it so different from a petrol one?
Nothing in particular. I just read a review on top gear once, presumably when s/s was in it's early days and they said it ruined the tdi experience. I just wondered what it was like to be honest. I was initially buying a 1.4cod and test drove it and didn't even notice the s/s.... However, I opted for the 184PS diesel after ordering instead but haven't tried it.
You notice it, as in you hear it stopping and starting (and feel it to some extent), but I don't really consider that an issue personally. Some people might get annoyed by it but I can't understand why myself!
Does anyone know if the Kufatec device has to remain attached, or is it, plug in, disable, remove.
I believe it has to remain attached. If you take it off, the next time the ignition is turned on Start/Stop will be enabled again.
If the engine stops, surely this will stop oil circulating, which will stop any lubrication of the turbo. So every time the engine restarts, the turbo is running dry, causing excess wear.
Probably not something to worry about for the first few years, but if you plan to keep your car for more than 4 years i would expect a turbo rebuild would be needed sometime.
Something audi probably welcomes as its money in there pocket.
If the engine is stopped, the turbo is also stopped and so doesn't need oil circulation to prevent wear. When you start the engine the turbo doesn't spool until after oil circulation has begun.
The normal reason for leaving the engine running on turbo cars is for cooling purposes. AFAIK the S3 has a water cooled turbo so assuming the water pump is still running (as veeeight suggests) then the turbo is still being cooled even while the engine is off.
Resistance is an indication of a dinosaur .......
