Hi, My audi 2008 Audi s5 is throwing up some codes, just curious if anyone can shed some light. ive tried swapping the cmp sensors from bank 2 to bank one and tested the 4 actuators its also just been carbon cleaned. i looked in the measuring blocks side of vagcom and noticed that bank 1 cam is adjusting by about half a KW but bank 2 cam just doesnt move.
3 Faults Found
001431 - Thermostat for Mapped Engine Cooling (F265): Open Circuit
P0597 - 004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Mileage: 197088 km
Time Indication: 0
Date: 2021.07.14
Time: 18:33:46
Freeze Frame:
RPM: 604 /min
Load: 34.1 %
Speed: 0.0 km/h
Temperature: 60.0°C
Temperature: 36.0°C
Absolute Pres.: 1020.0 mbar
Voltage: 13.843 V
000024 - Bank 2: CMP Sens 2 (G163) / Engine Speed Sensor (G28): Incorrect Correlation
P0018 - 001 - Upper Limit Exceeded
Freeze Frame:
Fault Status: 01100001
Fault Priority: 2
Fault Frequency: 1
Mileage: 197088 km
Time Indication: 0
Date: 2021.07.14
Time: 18:33:55
Freeze Frame:
RPM: 632 /min
Load: 29.4 %
Speed: 0.0 km/h
Temperature: 61.0°C
Temperature: 36.0°C
Voltage: 14.097 V
000025 - Bank 2: CMP Sens 4 (G301) / Engine Speed Sensor (G28): Incorrect Correlation
P0019 - 001 - Upper Limit Exceeded
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 197088 km
Time Indication: 0
Date: 2021.07.14
Time: 18:33:55
Freeze Frame:
RPM: 632 /min
Load: 29.4 %
Speed: 0.0 km/h
Temperature: 61.0°C
Temperature: 36.0°C
Voltage: 14.097 V
Readiness: 0110 1001
also some measuring blocks:
Address 01: Engine (8T0 907 560 F)
18:57:22 Group 091: Camshaft Adjustment (Bank 1 Intake)
600 /min Engine Speed (G28)
5.1 % Intake Camshaft Bank 1 Duty Cycle
22.0°KW Cam. Adjustment Intake B1 (spec.)
21.5°KW Cam. Adjustment Intake B1 (act.)
18:57:22 Group 155
18:58:18 Group 090: Camshaft Adjustment (Bank 1 Exhaust)
4.7 % Exhaust Camshaft Bank 1 Duty Cycle
-20.0°KW Cam. Adjustment Exhaust B1 (spec.)
-20.0°KW Cam. Adjustment Exhaust B1 (act.)
18:58:18 Group 091: Camshaft Adjustment (Bank 1 Intake)
22.5°KW Cam. Adjustment Intake B1 (act.)
18:58:18 Group 092: Camshaft Adjustment (Bank 2 Intake)
4.7 % Intake Camshaft Bank 2 Duty Cycle
22.0°KW Cam. Adjustment Intake B2 (spec.)
22.0°KW Cam. Adjustment Intake B2 (act.)
18:58:32 Group 090: Camshaft Adjustment (Bank 1 Exhaust)
5.1 % Exhaust Camshaft Bank 1 Duty Cycle
-21.0°KW Cam. Adjustment Exhaust B1 (act.)
18:58:32 Group 091: Camshaft Adjustment (Bank 1 Intake)
18:58:32 Group 092: Camshaft Adjustment (Bank 2 Intake)
5.1 % Intake Camshaft Bank 2 Duty Cycle
Wednesday,14,July,2021,18:59:04:46862
VCDS Version: Release 10.6.0
Data version: 20100630
18:59:01 Group 093: Camshaft Adjustment Adaptation
-4.0°KW Phase Position Bank 1 Intake
Phase Position Bank 2 Intake
-2.0°KW Phase Position Bank 1 Exhaust
Phase Position Bank 2 Exhaust
18:59:01 Group 094: Camshaft Adjustment (Intake)
21.5°KW Cam. Adjustment Bank 1 Intake
22.0°KW Cam. Adjustment Bank 2 Intake
Test OFF Cam. Adj. Test Bank 1 Intake
Test OFF Cam. Adj. Test Bank 2 Intake
18:59:01 Group 096: Camshaft Adjustment (Exhaust)
-20.5°KW Cam. Adjustment Bank 1 Exhaust
-20.0°KW Cam. Adjustment Bank 2 Exhaust
Test OFF Cam. Adj. Test Bank 1 Exhaust
Test OFF Cam. Adj. Test Bank 2 Exhaust
3 Faults Found
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 197088 km
Time Indication: 0
Date: 2021.07.14
Time: 18:33:46
Freeze Frame:
RPM: 604 /min
Load: 34.1 %
Speed: 0.0 km/h
Temperature: 60.0°C
Temperature: 36.0°C
Voltage: 13.843 V
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 197088 km
Time Indication: 0
Date: 2021.07.14
Time: 18:33:55
Freeze Frame:
RPM: 632 /min
Load: 29.4 %
Speed: 0.0 km/h
Temperature: 61.0°C
Temperature: 36.0°C
Voltage: 14.097 V
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 197088 km
Time Indication: 0
Date: 2021.07.14
Time: 18:33:55
Freeze Frame:
RPM: 632 /min
Load: 29.4 %
Speed: 0.0 km/h
Temperature: 61.0°C
Temperature: 36.0°C
Voltage: 14.097 V
18:57:22 Group 155
