I noticed this morning that my drivers window did not want to go all the way down or up by just flicking the switch once as it usually does and should. Anyone know the cause of this or if it is just a setting??
Normally when stuff like this happens it means the anti shut feature has been set off I would've said. I.e. to stop kids getting their arms stuck in there etc. Check that all the rubber is flush at the bottom of the window and in the channel as sometimes it can ridge and stop the window
