AWD and Tire pressure monitoring control modules - no signal / communication
thebasix
Garage
Hi guys,
I have A5 8TA 2013 3.0 tdi quattro. I found 2 faults using OBD Eleven which I cannot clear because they keep showing up. These are
1) All wheel drive control module - code: 01324
2) Tire pressure monitoring control module - code: 01325
As you can see on the screenshot, it shows "No signal/communication".
Is this a sensor/module issue or could be just fuse issue?
I mean, you're going to need to go check the fuse for those features individually - if they even have their own fuse. Could also be a relay.
A good fuse review is a great first step. TPMS replacements aren't terribly expensive, falulty TPMs may be throwing the control module.
