- Joined
- Jul 14, 2017
- Messages
- 95
- Reaction score
- 17
- Points
- 8
decided to do a little DIY and get rid of the sub standard woofer in the spare wheel well as you couldnt even tell when it was on!... bought this kicker dual coil 2ohm 150w sub and with a little assistance from a muliti-tool (to get rid of the moulding tags inside.. fits perfectly into the enclosure.) if you wire them up in series it makes it up to 4ohm which is only 2 ohm short of the original!.. i have checked and it leaves no codes on vagcom and once you block the port up to make it sealed just turn it on and turn it up! very good and relitively cheap upgrade!, I got the speaker +delivered for £110 from kicker website. packs a really good oem non over the top punch !
