B&O upgrade in B8.5
Jooles
GB
I'm considering upgrading the standard Audi set up.in my 2012 A4 Avant facelift to the B&O set up. I had an A3 Black Edition previously with Bose and that was miles better so I'm assuming the B&O will be similar? So just wondering if there's a definitive guide as to what I would need and from what car eg is the B8 installation the same as the 8.5?
I'd be fitting used so possibly from a breakers but while I was at it I don't have dab either so is that just a case of plugging the module and an aerial in?
The car is an S Line with MMI High, jukebox, sat nav etc. Thanks.
Sent from my SM-G780F using Tapatalk
I’m pretty sure it’s a major wiring change as the amplifier is in the boot and a concert car is not wired for it.
On a slightly different point, I wouldn’t bother. If your putting the work (and money) in to retrofitting something you will get defat better results from some good component speakers and a DSP (with built in amp). There are loads out there, the Audison AP8.9 bit is a fantastic bit of kit that has a 9ch DSP as well as having a built in 8ch amplifier (tweeters and components front and rear); the remaining DSP channel is used to supply the signal to a subwoofer amp.
The B&O is and upgrade over the standard, but it’s not great and not worth the money in my opinion, either to retrofit or as a spec option from factory. Both the Audi Bose and B&O systems have ok mods, no highs and no lows. Spend the money on a proper aftermarket system and you will get a full dynamic range and a much better sound stage.
Reactions: Simon
Agree with @OliNix Spend your money on aftermarket. The B&O speakers will be better Than the Audi Sound System, or whatever level the car was fitted with. But certainly not for the cost and ball ache of sourcing the equipment. A Digital Signal Processor, high end component speakers for the front, 10 or 12 inch sub and you'll have a far better sounding system than the B&O.
On top of that, it's highly likely that the speakers are not even B&O originals, rather a licensing agreement with a third part (I think it's ASK in Poland, bit I could be wrong).
I had the Concert in mine, non mmi, standard 10 package speakers. Upgraded to all aftermarket and very happy I did, particularly when I see other A4s with stock looking/sounding systems
Both good points - thanks, to be honest I'd not thought of that. Is there a complete kit available amp sub speakers etc or does it have to be made up?
Phone around to you local car audio specialist. I'm sure they'll put a package together that would sound good and include fitting.
Where are you based?
I'm in Nottingham
Also, if you're looking to upgrade functionality, forget adding DAB modules etc. Go straight for an Apple CarPlay/Andriod Auto interface retrofit. This thread tells you everything you need to know.
956
14
11K
735
