plimbley123
Hi Ime in stoke on trent just done the B6 to B7 Light up-grade and need them re codeing anyone local who can help ?
Yhanks in advance Dave
Hi.Why can't I find the "kufatec wiring abapter"?
Can someone send a link or a part number?
I just bought a 2004 S4 Cabriolet and it has newer B7 tail lights. One reverse light is out. I replaced the bulb, then the entire light assembly and still no reverse light on the drives side. There is an adapter attached to this tail light but there is not a part number on it. I am assuming this piece is my problem?
Do you have RHD or LHD car? LHD has rear foglight in left side and reverse light in right side.I just installed a piar of original tail lights and the drivers reverese light still doesn't work. Does anyone know how to fix this?
Kufatec adapter not fit us models. Harness with resistors belongs left side.I have a US car so the steering wheel is on the left side. I thought it was the Euro cars that had the fog light on the left. If it is a fog light how do I turn it on to show the inspector? Just pull out on the light switch?
The upgraded lights that were in the car had an adapter on just the drivers side. I removed it when I put the stock light in. I thought it was strange that only one side had an adapter.
I ordered a HEX-V2 from Ross-Tech and a used contol module 8E0907279F from eBay.
I ended up using a universal license plate light socket in the left tail light assembly. It is being powered from the right side reverse light power and grounded from the right side brown too. And duck taped in place. It worked perfect for the inspection. Not sure why the same trick would NOT work with the stock socket?I just installed a piar of original tail lights and the drivers reverese light still doesn't work. Does anyone know how to fix this?
