What kind of machine polisher do you use? Been thinking of getting one to give mine a go over but wouldn't mind knowing a half decent one to get.
That looks excellent. Mine is also a ming blue one. Over the years you have used one what pads and products have you found works the best?
Looks really well mate. What size adapters are you using for the wheels?
I have the pipewrex downpipe on mine and have the sports cat from them in a v-band so I can swap it out for the decat after the mot. Both are made well and passes the mot no problem with the sports cat on.
I'm not fitting it mate, would have to take a couple of days off work to get it done and tbh I am not a fan of lying on my back crawling under cars anymore, especially when it is my daily. Pipewerx are doing the lot so I get the drive in / drive out without getting my hands dirty experienceYeah its sort of fit and forget about it. Haven't heard anyone having problems with them when on just the fitting can be a bit of a pain to do but I'm sure you will smash it mate.
Another one of the classic 8L issues popped up last week, central locking decided to stop working and make a right noise when I tried to open / close the doors. Big thanks to @MPH for assisting with the diagnosis and tracking down a very well priced MK3 Golf vacuum pump with motor.
Swapped the out the motors this weekend and all is back to normal (for now )
I'm a little bit out of touch but i've found Hexlogic pads are brilliant, product wise it depends what you want to do, I gave up trying to perform high levels of correction years ago, nowadays, I used Dodo Juice Lime Prime which is great at cleaning the paint and really making the colour show, IMO.
Far from an expert but 4 S3's and 7 years with a 225 TT means I am certainly encountering issues that I have faced in the past!Great little read and it’s fair to say having owned 4 you are probably an expert!
I recently bought a Goodwood Green example (my first S3!) and as you say even 20 years on it still impresses.
I have the ‘little’ jobs to do to, my worst will be a few bits of surface rust in the usual places - roof rails etc.
Tje door car leather has done a similar thing on mine, is it a case of removing the card spraying in some contact adhesive and stretching it into place with a little weight on it to get it sitting nice and tight?
Keep the updates coming!
Si
They are notorious for collecting mud behind the back of the arch liner wise to take them off every so often for a good clean preventing wing corrosion looks good BTW.I've developed a sticky front caliper on the S3 so while confirming that diagnosis on Saturday I did what every S3 owner needs to do and pulled out the arch liner to clear mud out from the inner wing, I also went around the lip on the wing as that was full of packed in mud and grime. It really is shocking how much collects there. While I was there I gave the inner arch a good degreasing and spray.
I had a bit of a fight getting the liner back in, I really don't recall having the same issue on previous S3's i've had but trying to slot it in behind the wing lip was not an easy task!
New caliper next so i'll do new pads at the same time, while the wheel is off the passenger side I will give that the same cleaning treatment...
Inside looks clean!
What's the button for above the ignition?
Thanks I aim to keep on using mine for as long as possible!And I thought I was the only one still driving one after 20 years! Welcome back.
