Does have a idea if the BAM block will fit in A4 b5 Quattro Thanks Col
C Coltam Registered User Joined Nov 10, 2014 Messages 39 Reaction score 0 Points 8 Location Cm131SE Website www.facebook.com Feb 23, 2015 #1 Does have a idea if the BAM block will fit in A4 b5 Quattro Thanks Col
Broken Byzan Photographic Moderator Staff member Moderator VCDS Map User Joined Apr 26, 2004 Messages 13,202 Reaction score 471 Points 83 Location Cardiff, United Kingdom Feb 23, 2015 #2 not directly no. You need an AJL, APU or AEB
C Coltam Registered User Joined Nov 10, 2014 Messages 39 Reaction score 0 Points 8 Location Cm131SE Website www.facebook.com Feb 23, 2015 #3 I've got a AJL at the moment want to use the BAM block as it has the forged conrods and crank
T tom-tt Registered User Joined Dec 25, 2014 Messages 6 Reaction score 0 Points 1 Feb 24, 2015 #4 Pretty much any engine will fit with deep enough pockets lol
Broken Byzan Photographic Moderator Staff member Moderator VCDS Map User Joined Apr 26, 2004 Messages 13,202 Reaction score 471 Points 83 Location Cardiff, United Kingdom Feb 24, 2015 #5 BAM IS NOT forged, the crank is the same as any 06a style internal water pumped engine and the rods are identical to the 20mm ones you already have
T tom-tt Registered User Joined Dec 25, 2014 Messages 6 Reaction score 0 Points 1 Feb 24, 2015 #6 ^^ this The Pistons are forged however
Broken Byzan Photographic Moderator Staff member Moderator VCDS Map User Joined Apr 26, 2004 Messages 13,202 Reaction score 471 Points 83 Location Cardiff, United Kingdom Feb 24, 2015 #7 no more forged than what he has, exactly the same procedure goes into all 1.8t pistons manufactured by Mahle
T tom-tt Registered User Joined Dec 25, 2014 Messages 6 Reaction score 0 Points 1 Feb 24, 2015 #8 You know it
Broken Byzan Photographic Moderator Staff member Moderator VCDS Map User Joined Apr 26, 2004 Messages 13,202 Reaction score 471 Points 83 Location Cardiff, United Kingdom Feb 24, 2015 #9 tom-tt said: ^^ this The Pistons are forged however Click to expand... Nope, it's a process loosely based upon forging, but no different to any other 1.8t piston of the same CR
