Just for clarity……
Coding a battery is
not a necessity when you replace your battery, it’s a recommendation.
Battery charging systems have become more intelligent in recent year, and they alter the profile of the charge to maximise the life of the battery.
Battery charge and discharge characteristics change as the battery ages, and “coding” (you can just change one digit of the battery code) simply tells the onboard electronics that a new battery has been fitted, and resets the charging profile to “new battery”.
You won’t damage the battery if you don’t code it to the car, but it may have a slightly shorter lifespan.
Coding becomes a bit more important if you replace your battery with a bigger, higher capacity battery, because a larger battery needs a higher charge profile to maintain at full 100% charge. Also some MMI systems can display battery info (state of charge etc) and may not display correctly if the battery is not correctly coded to the car.
iI you’re changing to a larger battery, or different battery type, you need to change more than the battery code, you also have to select the battery type and capacity. It’s easy to do with the likes of VCDS (other tools are available…) and all the info you need is usually on a label attached to the new battery, or you can just scan the QR code found on most new batteries these days
