Battery Drain
~RS~
Been having an issue with my car since Saturday....
Battery was flat as a pancake after a short drive (about 5 minutes) to drop a mate home. Stopped outside for a quick natter switched engine off, when trying to restart the car the battery was having none of it.
RAC were called out, gave me a jump start, done a few checks on battery and to see if alternator was charging it. The battery is holding charge (it's only 2 years old max and is a Bosch S4) alternator was also working fine. As I'd been on the phone via cars bluetooth with DRL's on and engine switched off, for 20 or so mins a few days before that it was put down to this.
Sunday rolls on and after a 20min drive in the afternoon, car does the same thing after being switched off. RAC again called out checks done and all seemed well. Told again to drive car for minimum 30 mins to recharge the battery which I did before going home.
Monday afternoon, I'm off so I go to pick up my daughter from school, car starts fine I get there and she's already outside waiting so no need to turn off car and we drive off. Get home and turn off car before remembering to grab some milk, try to restart it and same f***in problem again. RAC called again! This time the RAC guy does a battery drain test, and says there's a big drain occurring after car has been turned off.
I've done a scan with vcds and here's what came up before I cleared the codes and scanned again:
Tuesday,26,June,2012,12:00:43:10074
VCDS Version: Release 10.6.4 (x64)
Data version: 20110418
Chassis Type: 1K0
Scan: 01 02 03 08 09 15 16 17 19 25 37 42 44 46 47 52 56 62 72 77
7D
VIN: WAUZZZ8P55A081076
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
37-Navigation -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
77-Telephone -- Status: OK 0000
7D-Aux. Heat -- Status: OK 0000
Address 01: Engine Labels: 03G-906-016-BKD.lbl
Part No SW: 03G 906 016 DT HW: 028 101 189 2
Component: R4 2,0L EDC 0000AG 7000
Revision: 12345678 Serial number: AUX7Z0D9FNT0NO
Coding: 0000078
Shop #: WSC 66565 257 00032
VCID: 78FBECD37243
No fault code found.
Readiness: 0 0 0 0 0
Address 02: Auto Trans Labels: 02E-300-0xx.lbl
Part No SW: 02E 300 041 A HW: 02E 927 770 AD
Component: GSG DSG 041 0822
Revision: 00004010 Serial number: 00000410180173
Coding: 0000020
Shop #: WSC 06314 000 00000
VCID: 102BB4737AF3
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No: 1K0 907 379 K
Component: ESP FRONT MK60 0104
Coding: 0023174
Shop #: WSC 06435 000 00000
VCID: 3A7F36DB0CCF
Address 08: Auto HVAC Labels: 8P0-820-043.lbl
Part No SW: 8P0 820 043 E HW: 8P0 820 043 E
Component: KlimavollautomatH13 0150
Revision: 034069 Serial number: 8P0820043E
VCID: 2E570A8BC087
Address 09: Cent. Elect. Labels: 8P0-907-279-30-H.lbl
Part No SW: 8P0 907 279 K HW: 8P0 907 279 K
Component: Bordnetz-SG H54 2501
Revision: 00H54000 Serial number: 00000007998692
Coding: F30C9E8390141C004F0000003000000000084E0364360802000000000000
Shop #: WSC 06752 128 38088
VCID: 458555277531
Part No: 8P2 955 119 B
Component: Wischer AU350 H01 0130
Coding: 00062736
Shop #: WSC 06752
Part No: 4E0 910 557
Component: REGENLICHTSENSORH10 0050
Coding: 00150573
Shop #: WSC 06752
6 Faults Found:
01259 - Fuel Pump Relay (J17)
009 - Open or Short to Ground
Freeze Frame:
Fault Status: 01101001
Fault Priority: 5
Fault Frequency: 1
Reset counter: 57
Mileage: 173208 km
Time Indication: 0
Date: 2012.05.29
Time: 18:47:00
Freeze Frame:
ON
Voltage: 12.25 V
ON
ON
OFF
OFF
OFF
02092 - Enabling Heated Seat
Freeze Frame:
Fault Status: 01111001
Fault Priority: 5
Fault Frequency: 1
Reset counter: 57
Mileage: 173208 km
Time Indication: 0
Date: 2012.05.29
Time: 18:47:00
Freeze Frame:
ON
Voltage: 12.25 V
ON
ON
OFF
OFF
OFF
02403 - Terminal 15 for Interior
012 - Electrical Fault in Circuit
Freeze Frame:
Fault Status: 01101100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 57
Mileage: 173208 km
Time Indication: 0
Date: 2012.05.29
Time: 18:47:00
Freeze Frame:
ON
Voltage: 12.25 V
ON
ON
OFF
OFF
OFF
01049 - Supply Voltage Term 50
012 - Electrical Fault in Circuit - Intermittent
Freeze Frame:
Fault Status: 00111100
Fault Priority: 1
Fault Frequency: 1
Reset counter: 90
Mileage: 173820 km
Time Indication: 0
Date: 2012.06.23
Time: 10:54:00
Freeze Frame:
ON
Voltage: 8.60 V
OFF
ON
ON
OFF
OFF
00446 - Function Limitation due to Under-Voltage
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 4
Fault Frequency: 2
Reset counter: 89
Mileage: 173820 km
Time Indication: 0
Date: 2012.06.23
Time: 11:00:00
Freeze Frame:
ON
Voltage: 8.95 V
ON
ON
OFF
OFF
OFF
01520 - Rain and Light Recognition Sensor (G397)
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 89
Mileage: 173820 km
Time Indication: 0
Date: 2012.06.23
Time: 10:51:00
Freeze Frame:
ON
Voltage: 7.95 V
OFF
ON
ON
OFF
ON
Address 15: Airbags Labels: 8P0-959-655-94.lbl
Part No SW: 8P0 959 655 C HW: 8P0 959 655 C
Component: Airbag 9.41 H10 2620
Revision: 91H10262 Serial number: 00362000Z4FM
Coding: 0034622
VCID: 428F4E3B641F
Address 16: Steering wheel Labels: 8P0-953-549-F.lbl
Part No SW: 8P0 953 549 F HW: 8P0 953 549 F
Component: J0527 H36 0070
Coding: 0014112
VCID: 418D41376119
Part No: XXXXXXXXXXX
Component: E0221 H06 0030
Address 17: Instruments
Cannot be reached
Address 19: CAN Gateway Labels: 1K0-907-530.lbl
Part No SW: 1K0 907 530 D HW: 1K0 907 951
Component: Gateway H08 0100
Revision: 08 Serial number: 2500104A06018A
Coding: 3F3F0BCA072103
VCID: 285BFC93E263
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Part No SW: 8P0 920 981 A HW: 8P0 920 981 A
Component: KOMBIINSTR. VDO H73 0300
Revision: D04 Serial number: AUX7Z0D9FNT0NO
Shop #: WSC 00000 000 00000
VCID: 366722EB38D7
Address 37: Navigation Labels:
VCID: 55A585678591
2 Faults Found:
Freeze Frame:
Fault Status: 01100010
Fault Priority: 7
Fault Frequency: 6
Reset counter: 57
Mileage: 173820 km
Time Indication: 0
Date: 2012.06.23
Time: 11:00:52
Freeze Frame:
Voltage: 10.30 V
Mileage: 655350 km
Count: 65535
Clock: 255:255
00856 - Radio Antenna
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 5
Fault Frequency: 1
Reset counter: 90
Mileage: 173820 km
Time Indication: 0
Date: 2012.06.23
Time: 12:46:55
Freeze Frame:
Mileage: 173830 km
Count: 2306
Clock: 14:02
Address 42: Door Elect, Driver Labels: 8P0-959-801-MAX1.lbl
Part No: 8P0 959 801 F
Component: Tuersteuerger. H10 0030
Coding: 0000048
VCID: 3E773ACB10E7
1 Fault Found:
00912 - Window Regulator Switch; Front Left (E40)
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K2 909 144 H
Component: EPS_ZFLS Kl.8 1502
VCID: 316D11F7D1B9
Address 46: Central Conv. Labels: 8P0-959-433.lbl
Part No: 8P0 959 433 C
Component: KSG H04 0050
Coding: 188000186D088505489FC63000
VCID: 3C7330C306FB
Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H02 1301
Part No: 1K0 907 719 B
Component: Neigungssensor 004 0003
Part No: 8P0 951 177
Component: Innenraumueberw.H03 0020
Address 47: Sound System Labels: 8Px-035-382.lbl
Part No SW: 8P4 035 382 HW: 8P4 035 382
Component: AB2 SUBWOOFERBOXH03 0180
Revision: 00002 Serial number: 10000001205592
VCID: F1ED51F79139
Address 52: Door Elect, Pass. Labels: 8P0-959-802-MAX1.lbl
Part No: 8P0 959 802 F
Coding: 0000048
VCID: 3F8947CF17ED
Address 56: Radio Labels: 8E0-035-192-RNSE.lbl
Part No SW: 8P0 035 192 H HW: 8P0 035 192 H
Component: RNS-E HIGH EU H72 0660
Revision: 01S Serial number: AUZBZ7F0957072
Coding: 0205755
Shop #: WSC 06314 123 00000
VCID: 346318E32EAB
2 Faults Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 6
Reset counter: 57
Mileage: 173820 km
Time Indication: 0
Date: 2012.06.23
Time: 11:00:52
Freeze Frame:
Voltage: 10.30 V
Mileage: 655350 km
Count: 65535
Clock: 255:255
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 90
Mileage: 173820 km
Time Indication: 0
Date: 2012.06.23
Time: 12:46:55
Freeze Frame:
Mileage: 173830 km
Count: 2306
Clock: 14:02
Address 62: Door, Rear Left Labels: 8P4-959-801.lbl
Part No: 8P4 959 801 B
Component: Tuer-SG H10 0010
Coding: 0000144
VCID: 3E773ACB10E7
Address 72: Door, Rear Right Labels: 8P4-959-802.lbl
Part No: 8P4 959 802 B
Coding: 0000144
VCID: 3F8947CF17ED
Address 77: Telephone Labels: 8P0-862-335.lbl
Part No SW: 8P0 862 335 N HW: 8P0 862 335 N
Component: FSE_256x BT H34 0520
Revision: 00000000 Serial number: 00000005023259
Coding: 0011422
Shop #: WSC 63140 123 00000
VCID: 418D41376119
Address 7D: Aux. Heat Labels: 1K0-963-235.lbl
Part No SW: 1K0 963 235 E HW: 1K0 963 235 E
Component: PTC-Element 0404
Revision: 00800000 Serial number:
VCID: 2D550D87CD81
End ---------------------------------------------------------------------
Address 01: DTCs cleared
Address 02: DTCs cleared
Address 03: DTCs cleared
Address 08: DTCs cleared
Address 09: DTCs cleared
Address 15: DTCs cleared
Address 16: DTCs cleared
Address 17: DTCs cleared
Address 19: DTCs cleared
Address 25: DTCs cleared
Address 37: DTCs cleared
Address 42: DTCs cleared
Address 44: DTCs cleared
Address 46: DTCs cleared
Address 47: DTCs cleared
Address 52: DTCs cleared
Address 56: DTCs cleared
Address 62: DTCs cleared
Address 72: DTCs cleared
Address 77: DTCs cleared
Address 7D: DTCs cleared
Chassis Type: 1K0
7D
VIN: WAUZZZ8P55A081076 Mileage: 173980km/108106miles
Coding: 0000078
VCID: 78FBECD37243
Readiness: 0 0 1 1 1
Coding: 0000020
VCID: 102BB4737AF3
Coding: 0023174
VCID: 3A7F36DB0CCF
VCID: 2E570A8BC087
VCID: 458555277531
Coding: 00062736
Shop #: WSC 06752
Coding: 00150573
Shop #: WSC 06752
2 Faults Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 57
Mileage: 173989 km
Time Indication: 0
Date: 2012.06.26
Time: 12:04:00
Freeze Frame:
ON
Voltage: 10.10 V
ON
ON
OFF
OFF
OFF
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 57
Mileage: 173989 km
Time Indication: 0
Date: 2012.06.26
Time: 12:04:00
Freeze Frame:
ON
Voltage: 10.15 V
ON
ON
OFF
OFF
OFF
Coding: 0034622
VCID: 428F4E3B641F
Coding: 0014112
VCID: 418D41376119
Address 17: Instruments Labels: 8P0-920-xxx-17-MY7.lbl
Revision: D04 Serial number: 2249DD04002426
Coding: 0000443
Shop #: WSC 00022 210 98720
VCID: 366722EB38D7
VCID: 285BFC93E263
VCID: 366722EB38D7
Address 37: Navigation Labels: 8E0-035-192-RNSE.lbl
Coding: 0205755
VCID: 346318E32EAB
Coding: 0000048
VCID: 3E773ACB10E7
VCID: 316D11F7D1B9
VCID: 3C7330C306FB
VCID: F1ED51F79139
Coding: 0000048
VCID: 3F8947CF17ED
Coding: 0205755
VCID: 346318E32EAB
Coding: 0000144
VCID: 3E773ACB10E7
Coding: 0000144
VCID: 3F8947CF17ED
Coding: 0011422
VCID: 418D41376119
VCID: 2D550D87CD81
Here are the results after codes cleared:
Tuesday,26,June,2012,18:23:21:10074
Chassis Type: 1K0
7D
VIN: WAUZZZ8P55A081076 Mileage: 174040km/108143miles
17-Instruments -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
Coding: 0000078
VCID: 78FBECD37243
Coding: 0000020
VCID: 102BB4737AF3
Coding: 0023174
VCID: 3A7F36DB0CCF
VCID: 2E570A8BC087
VCID: 458555277531
Coding: 00062736
Shop #: WSC 06752
Coding: 00150573
Shop #: WSC 06752
3 Faults Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 58
Mileage: 173989 km
Time Indication: 0
Date: 2012.06.26
Time: 12:18:00
Freeze Frame:
ON
Voltage: 10.65 V
ON
ON
OFF
OFF
OFF
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 58
Mileage: 173989 km
Time Indication: 0
Date: 2012.06.26
Time: 12:18:00
Freeze Frame:
ON
Voltage: 14.15 V
ON
ON
OFF
OFF
OFF
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 58
Mileage: 173989 km
Time Indication: 0
Date: 2012.06.26
Time: 12:18:00
Freeze Frame:
ON
Voltage: 12.30 V
ON
ON
OFF
OFF
OFF
Coding: 0034622
VCID: 428F4E3B641F
Address 16: Steering wheel Labels: None
VCID: 55A585678591
Coding: 0000443
VCID: 366722EB38D7
VCID: 285BFC93E263
VCID: 366722EB38D7
Coding: 0205755
VCID: 346318E32EAB
2 Faults Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 98
Mileage: 173989 km
Time Indication: 0
Date: 2012.06.26
Time: 12:06:35
Freeze Frame:
Voltage: 11.50 V
Mileage: 174040 km
Count: 2606
Clock: 18:17
00879 - Connection to Speaker Front Right
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 5
Fault Frequency: 1
Reset counter: 57
Mileage: 173991 km
Time Indication: 0
Date: 2012.06.26
Time: 13:52:03
Coding: 0000048
VCID: 3E773ACB10E7
VCID: 316D11F7D1B9
VCID: 3C7330C306FB
VCID: F1ED51F79139
Coding: 0000048
VCID: 3F8947CF17ED
Coding: 0205755
VCID: 346318E32EAB
2 Faults Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 98
Mileage: 173989 km
Time Indication: 0
Date: 2012.06.26
Time: 12:06:35
Freeze Frame:
Voltage: 11.50 V
Mileage: 174040 km
Count: 2606
Clock: 18:17
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 57
Mileage: 173991 km
Time Indication: 0
Date: 2012.06.26
Time: 13:52:03
Coding: 0000144
VCID: 3E773ACB10E7
Coding: 0000144
VCID: 3F8947CF17ED
Coding: 0011422
VCID: 418D41376119
VCID: 2D550D87CD81
Would really appreciate any ideas as to what could be causing the issue as it's one of those things that may cost a bomb just diagnosing and end up costing next to nothing to put right.
Cheers!
The only real problem I've had with my car Rich was battery issues, and this was in the first year of me having it. It kept draining also, but came up with no faults on VCDS, went into Audi about 4 times, which they left it overnight to do a full drain test, each time it kept coming back no faults, then week later same problem. I asked them to replace the battery, but said they couldn't as they couldn't prove a fault.
Finally on the 5th time it went in, they said it did test faulty and replaced it, never a problem with that one ever since! I've recently upgraded it to Varta Dynamic Silver, you can get them from TPS lad.
VARTA SILVER dynamic - batteries for cars - VARTA Automotive
If battery and alternator checked out ok and with so many under voltage codes, I'd suspect a bad earthing somewhere causing radio and seats to draw power.
Check the grounding terminal under battery, may have some corrosion & not getting good contact.
Also try disconnecting your radio, BT & anyother systems to see if it stops the problem.
Looks like you need to decode seat heating & fuel pump in 09 aswell.
Thanks guys I really appreciate the help. Just went to start her up and battery is flat again.
NHN the BT module is under the carpet as neatly fitted by yourself... Will I have to get the chair and carpet out to disconnect or is there an easier way to do it. When you say disconnect the radio (assuming RNS-E) do you mean just pull the power from behind it?
How would I go about decoding the seat heating and fuel pump in 09?
I've had a look at when I bought my Bosch S4 battery (same as the Varta but 4 year warranty instead of 5) it was purchased along with new starter motor (heat soak issues) 0n 27/11/2010 so its not even 2 years old yet and only had issues lately. Still think abttery maybe at fault? Even after RAC test etc??
Really doing my nut in and costing excess money in cabs!
you should be able to pull out one of the fuses by the drivers side door to kill the radio
the seat heating coding is either in the central electrics module or convenience module... cannot remember right now
to access the bluetooth you can undo the 4 spline bolts holding the seat down and then let it fall back onto the rear seat and disconnect the wiring.
also get yourself a self charger for the battery... those things dont cost much but are great when you need it. have a look here: Halfords | Car Battery Chargers | Battery Chargers for Cars
Yeah just pull the plug on rns, charge battery with something like a ctek charger mate, brilliant chargers, the xs4003 are great for your size battery tbh, think its now the mxs 5.0 about £50, then see if its draining still, if so then unplug bt & yes unfortunately unless you cut the power feed to the bt unit thats behind radio to, then you need to lift seat & unplug directly, but this wont take long to do, then recharge again & see if its still draining down.
Have you fitted anything else recently?
Just disable the options in 09.
RNS is fused under bonnet & check its not powering other systems aswell before you pull.
After you pull a fuse (Radio/Rnse/Phone/etc), put an amp-meter across the fuse contacts, and you will quickly find out where your battery power is going to. Hope this helps.
I haven't fitted anything lately except a hybrid tubro, electronics wise though nothing has changed afaik.
Will get the charger tomorrow and get to pulling plugs, fuses re-coding and whatever else is required.
I love these forums! :wub:
Mucho gracias guys!!!
I charged the battery using the 'recon ' mode until full.... removed it and charged indoors yesterday and within an couple hours of removing the charger it had goin back down from '7' which is fully charged to '3' which is pretty much dead
I've charged it again for few hours this morning and left it unplugged now for an hour or so.... going to take the battery back to eurocarparts for a replacement n keep my fingers + toes crossed wishing it's the battery at fault!
I let you guys know how I get on the while.....
TBH if the batteries drained so much it should take longer than few hours to charge fully, so maybe it does have an inherent fault, my battery took a day or 2 when I didnt use car for a long period.
I had a big feeling it could of been the battery.:unsure:
well its good i suggested that test to you rich... at least its isolating the issue now... im surprised the RAC didnt catch onto this though :whip:
Hi N8, from what I've been told and read online the bosch silver I have and varta you recommend are the same battery, they have the same specs etc. Cheers for the help though it's all appreciated never the less!!
Alright Nige..... The battery was on charge from about 3:30pm to 1am they do recommend 12 hours for my battery according to instructions but for it to be flat as nail head in an hour or so had me rethinking what the problem maybe. It held charge but the charge dissipated so quickly it was crazy. Eurocarparts tested it and said it was pants lol, so out with the old and in with the new :)
Diggz is that why you didn't pop round with the RNS-E removal keys yesterday then? :think:You big physic you :happy: Can you tell me the winning lotto numbers for Saturday's draw please..... Have had my eye on the Aventador LP700-4 for a whiles now lmao!!:eyebrows:
Yes Ash mate!! Good suggestion for sure :)
I'm also surprised the RAC didn't catch onto it!?! But maybe as it's been semi-charged while driving and drained so many times over the past 6 days it's packed up?? I dunno but I really hope it's just the battery because it's such a pita to have to remove fuses, chairs etc you know I'm bob at that stuff lmao!
Will keep you guys posted as usual.
Have a good day guys!!!
lol........I had to pick up somebody around that time....plus I thought it would be better if we waited for ash to see what other things it could be.
I'll give u a little in sight too the lottery game thou.......That's after I've won my 5 Mill :eyebrows: ..lol
I'll buy u one of the New Joints " A-Class AMG" :wub:
20
3K
768
NHN
