Good news mate, if your stereo and glove box connector were wired long before it started playing up then chances are they weren't the problem.Well everything is back together and the car has been locked for 30 minutes and the light has stayed off. It went off shortly after locking.
I always hook up a permanent live in the glove box on my cars. Great for charging things you don't want on display.
No that's an earth wire.I'm not a great fan of those connectors, I would solder or use a crimp connector.
The black/white wire is an ignition feed........yes?
Until the ignition is turned off, then the small load you are running will get a path to earth through all the things that come on with the ignition.Nah.....2 lives won't do anything!!
You can't deactivate the immobiliser with VCDS . The insulation on the wiring looms is very porous so water does get in there. Normally thats not an issue if there is just wire in there but there are many soldered joints where common wires meet in the loom.
There are plenty of these in the loom on the floor by the CCM. When these get wet over a period of time they rot and you get intermittent connections. They are usually common earth points in the loom.
This is from a Golf thread but you get the idea, The wiring is the same in the Audi.
http://uk-mkivs.net/topic/97141-mkiv-interior-monitoring-alarm-wiring-help/page-4
Karl.
