I am going to buy a Ctek trickle charger and want to have a permanent connection to the battery, what size are the terminal bolts so I can get the right size for the eye connector?
batteries should ALWAYS be charged outdoors or in very good ventilation , charging produces explosive hydrogen gas , not a good idea to have a permanent charger connected in the boot or under the bonnet notwithstanding the attached ventilation tube the old merc A series had the battery under the driver seat also a dodgy decision even if modern batteries gas less than older versions
