Battery voltage help
vw754
vorsprung Durch Technik
U.K
Anyone know if these readings are any good, battery been fully charged around 2 weeks ago and ive driven car today after about 4 days of been parked up.
If your battery is an EFB type, you should run a reconditioning program on it using a smart charger, like a CTEK 5Amp one and see if these values u=improve, if you have an AGM battery then not is not possible or useful.
Lack of use is a killer for a battery full stop, if you can use a battery maintenance charger during periods of light infrequent use then do so as it will save your battery.
Reactions: vw754
Looking at the data this was done igniton On, Engine off ? And the readings look fine
Reactions: vw754
