Hi all,
Have successfully fitted the facelift front end with bi-xenon headlights to my 2005 AUDI A3 3.2
Used the kufatec adapters with 2 extra wires running to the module in drivers footwell for bi-xenon shutter + DRL's.
I have also successfully coded using VCDS (Xenon headlights ticked, Daytime running lights Active ticked (Scandinavia)
I have the Bi-xenon shutter wired and working correctly, however the DRL's will not work for some odd reason.
I have read the forums and instructions provided with the adapters thoroughly, all saying PIN 3 on PLUG/BLOCK A + D for each side respectively, however the DRL's will not turn on!
They definitely do work as when I was wiring I accidentally put the DRL wire into the bi-xenon pin and when pulling the stalk to test the flash the DRL's were flashing lol
Also the headlights + taillights are both staying on when switch is set to 0
(Car was originally fitted with single xenon headlights with AUTO function)
Any help is much appreciated
Kind regards
Kind regards
