just017
- Joined
- Apr 19, 2009
- Messages
- 436
- Reaction score
- 3
- Points
- 16
Recently my ABS pump went wrong, got a replacement off ebay and in terms of fault codes, it works, I decided to fully flush the brake system. So, all the fluid out, I then used a pressure bleeder and filled the system up again with fresh fluid, bled all 4 callipers (several times) but still the brake pedal is only about 50% effective. Just to note, each time i have used Vag Com to purge the ABS pump.
Are there any other nipples to bleed the system? If so where.
Regards
Regards
