Brand New Car
danilo bandeira
Hello folks...
i had a Lamborghini Gallardo Spyder Lp560-4 2010-2010, but, now, i have a brand new 2015 Audi RS6.
I have some doubts and i'd like to know if you can help me
1) how can i unlock the TV to see that with the car in motion?
2) What is the most common upgrades in RS6?
Tks a lote
Danilo from Brasil!
Reactions: voorhees
Welcome to ASN Danilo,any pictures of these cars ?
@NHN can answer the TV question
1531702 10152946150849084 7386380498378053773 n
1779891 10152946150774084 6811638683054996619 n
10801494 10152946150954084 4090639091853471950 n
10849985 10152946151079084 6941945427333356638 n
Reactions: mister.c., voorhees and Sandra
Welcome to audi-sport.net. Love the car. Enjoy the forum. :) x
Here you go for all the Video in Motion :
Video In Motion - prevent the car from suppressing DVD playback once the speed of the car rises above 5mph
I used the same technique as in my C6 with MMI 3G. These are the steps I followed:
[Select]
[5F-Information Electr.]
[Advanced ID - 1A]
Make a note of the Serial Number
Go to Enable VIM TV-playback using VCDS/VAG-COM in your Audi MMI | trick77.com
Follow the link for MMI 3G
Enter your serial number into the input field
Make a note of the personal login code and the alternative login code it returns
[Security Access - 16]
Enter your personal login code.
[Do it!]
If you receive a "code not valid" message try the alternative code. If neither code works it's likely that your control module doesn't support VIM adaptation.
[Adaptation - 10]
Select channel 48
Press read
Set the value from 0 to 255
Press test
Press save
Press "Done, Go Back"
Close VCDS and reboot your MMI as detailed in step 5 above
