Broken wire in engine bay?
craigy
hey you lovely people
I made a discovery in my A3 2006 56 plate 2.0tdi
so a few days ago while changing my side light/w5w bulbs my grandfather pointed out this broken wire, i never noticed it before and from what i can tell its been broken for quite some time prior to my purchase of the car due to the inch of corroded wire under the insulation
its next to the left headlight i have googled and found no information on what it is for or what it connects to it almost looks like it's attached to the radiator but then i can't quite tell
I have managed to repair the cable but wondered what this cable is for as i scanned before and after the repair and had the same few error codes
Z35 aux heater
air quality sensor
single wire
radio (aftermarket)
so nothing worrisome
do any of you guys have a clue as to what its for?
your answers are very much appreciated
nluk100
Did you clear the codes as sometimes they can be present for years and the actual faults have been fixed or have cleared themselves.?
Troubs12
Active Member
That’s the connector for the bonnet open switch buddy I’m 99% sure that the switch is normally open and closes when the bonnets open.
It’s one of those that you wouldn’t notice till you either had an oil light on or wondered why the wipers were still going when the bonnet was opened.
craigy
i cleared them beforehand just incase and had the same few errors,
if that's the case it's an odd location for the connector so far from the bonnet latch, but make sense since nothing appeared to be different after repairing the wires
i never even knew the wipers were disabled when the bonnets open so never thought to check that before and after fixing it
thanks for your help guys
Troubs12
Active Member
Anytime bud it’s easy to test if you want to be 100% open the bonnet and the dash should show it open. Disconnect the connector and it should show it’s closed.
craigy
bit of a dumb moment but no warnings on the dash of it being open, but i now do wonder if it has ever showed that warning since i have had the engine running and bonnet open but did not notice a dash warning, i will check that before i leave for work in a few hours, warning for both doors and boot work,
so it could be a case of the wire not being the switch but something else, i will do more googling and see if i find anything
