Caddy Wiring for Fogs?
Cockneyrick
Crewe
So this relates to a Caddy, but most VAG are the same.
I need to know the fog light wiring colour & pin position., as i have fitted a bumper with fogs.
Have changed the switch to a fog one, & all wiring is in place but for the trigger wire from the switch to the relay.
Original non fog switch had 8 of 10 pins, fog enabled has all 10. I need to wire the trigger to the correct pin/wire to get the fogs to work.
Can anyone help? Pic is of old 8 pin switch.
You need the elsawin schematics for your year, chassis etc as it's not all the same, these days it's a signal from the switch to the CE module which then turns on the relevant lights, you haven't given any data on the caddy so it's hard for people to advise.
