In the process of swapping the oil pump balance shaft the locking pin in the camshaft sprocket is jammed, it rotates about 5 degrees and have tried to pull it out but no luck, any help would be greatly appreciated. Thanks
If you can get a socket on the central bolt in one of the gears, rock it slightly and that should free the stuck pin. Pull on the pin while you're doing it. You may need to bump against the pin to actually free it.
Thanks, Will give that method a try in the morning. For my understanding when you say ‘bump against the pin’ you mean tap it? In or side ways or other?
Sorry, I didn't make it quite clear. When you jog the cam gear with the socket, it will bump the pin. You may need to bump it in both directions of turn on the gear.
