Tried the fuse box by the driver's door, but the only thing mentioning auto gearbox in there says V30 automatic transmission and has no fitting for a fuse!
Getting the fault code for faulty control module and the car goes into transmission limp mode after about 5 mins. Had the codes read at a VAG specialist. Pretty sure I need a new one but can't find one with my part number currently.
Looked under the carpet and took the TCM out. While it was a bit wet under the carpet, there was no water in the box the TCM sits in. It was bone dry in there.
