If you check the 20 pin red connector on climate unit, pin 10, see if this has a wire in, if not, then yours would appear to be the newer type that removed the G89 sensor, if the wires present, then you need to find the sensor.
G89 - Fresh air intake duct temperature sensor
It shows approx 4 of these sensor types, all plummed into the ducting & they look accessible.
