Must of drank all the recent rain water.
Think I have more plugs to unplug somewhere to fix this... not sure where yet, only unblocked the ones under the battery the other day!
On a possibly related note my car is also still getting an intermittent "Electronic Stabilization Program" light with a flashing "Glow Plug System" light and no throttle response, throttle literally does nothing and you have to coast in limp mode like an automatic.
The car also had flashing rear brake lights when I unlocked it which I think could also be related.
Had it on Vag Com which returned the following:
Address 01: Engine Labels: 038-906-019-AVF.lbl
Part No: 038 906 019 GQ
Component: 1,9l R4 EDC 0000SG 1524
Coding: 00002
Shop #: WSC 63351
VCID: 6C8034AE4F9FC597BDF-4B3C
WAUZZZ8E52A007313 AUZ6Z0A0079950
3 Faults Found:
18080 - Coolant Fan Control 1
P1672 - 35-10 - Open or Short to Ground - Intermittent
19561 - Valve for Intake Manifold Flap (N239)
P3105 - 35-10 - Open or Short to Ground - Intermittent
18047 - Accelerator Position Sensor 1/2 (G79/G185)
P1639 - 35-10 - Implausible Signal - Intermittent
Readiness: 0 0 X X X
Address 03: ABS Brakes Labels: 8E0-614-517.lbl
Part No: 8E0 614 517
Component: ABS/ESP front D1320
Coding: 04255
Shop #: WSC 06435
VCID: 6596418AAC75F4DFE21-51F2
4 Faults Found:
18258 - Powertrain Data Bus
P1850 - 35-10 - Missing Message from ECU - Intermittent
00287 - ABS Wheel Speed Sensor; Rear Right (G44)
27-10 - Implausible Signal - Intermittent
00290 - ABS Wheel Speed Sensor; Rear Left (G46)
01314 - Engine Control Module
79-00 - Please Check Fault Codes
Address 08: Auto HVAC Labels: 8E0-820-043.lbl
Part No: 8E0 820 043
Component: A4 Klimaautomat 0711
Coding: 00000
Shop #: WSC 63351
VCID: 5EE46E668923A70723B-5184
3 Faults Found:
00757 - Right Vent Temp Sensor (G151)
30-00 - Open or Short to Plus
00819 - High Pressure Sensor (G65)
01312 - Powertrain Data Bus
Address 17: Instruments Labels: 8E0-920-9xx-8E2.lbl
Part No: 8E0 920 950 C
Component: KOMBI+WEGFAHRS. RB4 D14
Coding: 00400
Shop #: WSC 21215
VCID: 290E0DBA80ED10BF069-5184
1 Fault Found:
49-10 - No Communications - Intermittent
From what I've seen people think it could be the seal around the ECU letting water in? Brake light switch? Throttle position sensor? ABS sensor? Fuse?... What I'm trying to say here is I'm lost haha.
Absolutely any ideas are highly appreciated.
Coding: 00002
Shop #: WSC 63351
3 Faults Found:
Coding: 04255
Shop #: WSC 06435
4 Faults Found:
Coding: 00000
Shop #: WSC 63351
3 Faults Found:
Coding: 00400
Shop #: WSC 21215
1 Fault Found:
