Catching Front Wheel
terrysingh
hey dudes!!! got a small problem, nothing major.... just seeing if anyone else has had the same problem......basically, when turning my steering while driving...say into a road with a **** surface, or with a dip at the end... or reverse camber, my front wheel seems to be catching the small trox screw at the top of the front arch, only very briefly, not causing and damage or marks, its just a shock to hear when it happens,
its only done it 2-3 times since ive had the car, but the roads are **** where i live,
anyone???
Randomjim
It happens on mine too. Either get your arches rolled. Raise your suspension or live with it really.
terrysingh
gonna raise the front 1/2 a tread tomorrow, see if that make a difference, only realy does it when all the cars weight is on one wheel when cornering into a turn on a raise....weird????
hopefully sort it tommorow, if the weather holds out!!!!
Randomjim
That's when mine does it too. I'm gonna put up with it on mine as i don't want to raise it.
gtiglasgow
Remove the screw and cut off the plastic clip!!!
