Quattro Matty
My front tyre's will need changing before my next MOT, my question is with my A3 being a quattro do all four need replacing or can I just change the fronts for new tyre's ???
does it not engage when you pull away?
New tyres should go on the back, move the used rears to the front.
i suppose this is why people upgrade the haldex
What do you mean upgrade the haldex ???
Thanks for the replys chaps I'll buy 2 new tyre's stick them on the rears and move the old rears to the fronts..
what problems is that actually likely to cause if any?
you said it your self there... Uk roads are often like patch work quilts, the varying surfaces will have varied coefficients of friction anyway..."varying surfaces" "different coefficients of friction"
I am far from suggesting anyone does this. . .have a different type of tyre on each corner
unfortunately, due to water being a liquid, it's not kind enough to sit evenly on the road. so even there being a puddle of water on one half of the road and not the other is also just as likely to induce a spin.one wheel might be able to cope and disperse the water and keep traction but the other with less tread might not
Thanks for your âhumbleâ opinion
is the performance haldex controller plug and play? or having to programme in?
ooops sorry dude
