Konstantinos
Hello guys! I
Some days ago my engine light suddenly went on after quite a long trip
A local garage scanned the car for codes and 3 different came up.
P0327 Knock sensor 1 signal too low
P2177 System too lean off idle bank 1
P0507 Idle air control system RPM higher than expected
Lets star with knock sensor. I’m planning on taking it out, inspect it, clean the area, check wiring and socket and retorque to factory specs hoping for the best
For the lean idle code, firstly I searched for possible vacuum leaks around the engine bay and found out that the vacuum hose that runs from the intake to the small plastic valve and then to vacuum pump for the brake servo are a bit worn out and partially sliced so this might be a problem. Also checked the brake Pedal after letting the car rest for some hours and it’s solid hard until I fire the engine up.
So we are talking for a possible vacuum leak from the brake booster hoses? Is it possible that this is the problem?
Lastly, for the p0507 I’m planning on ordering a new pvc valve as the one I have now is stock and the engine has 110k kilometers by now.
Anyone with experience on the subject for some help?
Thanks a lot!
Thanks a lot!
