Hi!
thought it was about time i carried this task out as my car as far as i know has never had it done!
its a 2.0 tdi 140 s line avant with aprox 78k on the clock!
first of all i would like to thank low fuel for this thread as i followed this while doing it and found it was a good how to thread! cheers dude! well done mate!
http://www.audi-sport.net/vb/audi-s...-2-0-tdi-problems-problems-problems-help.html
anyway! here goes!
tools needed are t30 torx, 6mm allen key, (shortened helps), spark plug brush, carb cleaner, petrol!
surgical gloves and kitchen roll
i know, i know! i need an audi badge! lol
one filthy anti shudder removed first off,
then the egr! not that bad i thought! i was expecting worse after seeing some of the images on here! must be the v power i only run her on maybe!
i filled an old maggot box out my fishing tackle with about £2.50 worth of unleaded petrol and let the egr soak here for half an hour or so!
while i got to work cleaning the anti shudder up with carb cleaner!
a lot better! not perfect but i did not want to damage the flap! so cleaned up the best i could without braking anything!
the old gaskets and o ring i removed!
halfrauds carb cleaner! around £6 a tin! i probably could have used 2 tins! but got a pretty good result off the 1 tin never the less!
(notice ASN in the background)
these are my mucky paws even after using surgical gloves throughout!
not a clean job at all, but very rewarding and quite easy if you take your time! and follow low fuels guide!
you cant go wrong really!
beer time! a bottle of asdas finest cheap french muck!
its quite nice actually! lovely ice cold and a refreshing change to stella!
anyway! here goes!
