Ok so i have coded my car to have CHL and nothing happens lol i have then seen that you need the correct switch next to the light switch so as mine just has a DRL one fitted i have ordered one with CHL/DRL knobs.
Is anything else needed to have this function?
i unplugged the light switch and switched the ignition on and the lights came on so presume because i have auto lights/drls/xenons that i have a highline module so in theory i can just fit the switch and the wiring should already be in place or is additional wiring needed from the CHL switch to control unit for this modification to work. Anyone know what pins i need to check at the existing DRL switch to confirm if wiring is needed or not.
any help/feedback appreciated
