max14632
Hi everyone. I just bought a 2010 2.0t quattro a3. The issue is if i floor it at about 4200rpm the car chokes, feels almost as if i tapped the brakes really fast. If i do about 50% throttle it happens at around 4500rpm, not as violent but still the same choke. Before 4k rpm car drives perfectly fine, consistent, no issues at all. Problem is i dont get a check engine light, even if i do few WOT pulls in a row every time hitting choke point. After the “choke point” if i let go of the gas pedal and let the rpms fall, the car drives fine again like nothing happened. If i keep the gas pedal while its choking it starts to shake violently and rpms bounce at around 4k.
So far i replaced a diverter valve with an upgraded 1, and also replaced a n75 valve. That made no difference. HPFP is putting out 2200 psi and holding all the way to the choke point(4200rpm), turbo seems to be working too, ive seen 10psi peak and then it falls off to about 6-5psi shortly after(im not sure if thats normal numbers). I have logs but the app wont let me post if i attach them. Let me know if you guys have any ideas or if any of the numbers seem off. Thanks
