4sprung
Hi Guys
I have an A3 1.8T (AGU) and the clutch broke a few weeks ago. I then purchased a copper clutch setup.
The kit included a 6 button clutch, a pressure plate from an A4 1.8 and a flywheel from a 2.0 Beetle/Golf 4.
The car was sent to through to a mechanic. 1st issue was the starter. The pinion on the starter was not moving the fly as mine had 10teeth. I was told I needed a 9 tooth pinion. I got the starter modified to a 9 tooth pinion. Now the mechanic tells me the flywheel is too big and is touching the gearbox and is not turning.
This same kit was installed on the A3 1.8T (AUM) and is working fine.
I would like to know, am I wasting my time with this kit? Will it be able to work?
