2000km back, aboult half a year ago… my drains are probably somewhat blocked since my passanger footwell is damp… just the passanger thoCheck the scuttle drain isn't blocked. When was the pollen filter last replaced?
Disable the econ mode and you will see the differenceWhen it rains and i drive the car the rear windows mist up like crazy… i have ac on at 20 degrees all the time just on econ mode… anything i can do?
That's not going to be the reason for a damp footwell, more likely that the scuttle is full of water. Best to empty it before you have electrical gremlins popping up, the wiper motor will probably be submerged.My ac currently doesnt work… my pulley is bad and there is no belt… is that the cause?
Lol well yes, the Aircon dehumidifies the air. Without it, all the damp from outside air will be pulled inside.My ac currently doesnt work… my pulley is bad and there is no belt… is that the cause?
So how did cars manage BEFORE aircon then?Lol well yes, the Aircon dehumidifies the air. Without it, all the damp from outside air will be pulled inside.
The scuttle is under the battery? Can also the seals around doors be faulty?I never had a misting problem in cars without aircon, unless the scuttle was flooded
Scuttle is at the base of the windscreen. It's the trough that the wiper motor sits in. The cover is usually held by the rubber gasket that the bonnet sits onto when it's shut.The scuttle is under the battery? Can also the seals around doors be faulty?
