Its a weird issue. Coolant temp keeps dropping whilst im driving but will reach 90c no problem stood still/slow driving.
So I though ok itl be thermostat (ive already replaced sensors at this point). So new stat is on. Same issue.
But last night I noticed after my commute home when I took the cap off the coolant bottle there was NO pressure even thought the engine should have been hot.
So I let the engine get back up to 90c put the cap back on and left engine running for good 30mins. Took cap off again expect a huge TSSSH, but just a little TSH so I guess it is keeping pressure.
Going to get it pressure tested tomorrow but has anybody else got any ideas?
Water pump is working fine as when the engine is rev'd you can clearly see coolant flowing through the bottle so im not sure what else it could be.
Engine is not over heating at all and fans kick in after a sprinted drive (even though temp reads 60c) so somethings fishy.
Oh and since this issue was there before thermostat change also, I thought Id test the old one. The stat is open when cold and closes when hot. I have another spare one from ECP which was leaking and we didn't end up using, that behaves the same so Im guessing this is correct? Im at whits end
Any ideas? Its a 2.0 TFSI Quattro
