I have the ea888 gen3 engine. My temperature reaches 90° on the dial rather quick. With in a mile, it always has. It never goes above 90° I logged Torque Pro in and that said my coolant was 104°. Does this sound about right?
Not 100% the same, but my 3.0tfsi in this weather at the moment hit 90 within about 2-3 mins of starting it up, before I get onto the main road it is 90 which is about half a mile
And 90 will show on the gauges between a set parameter of actual temp given by the temp sensor as it fluctuates, it104 sounds a bit high but may be within the limit.
