Cruise control coding, derby?
Swinny
Could anybody point me in the right direction? For somebody in the midland area to code in my cruise control? I have fitted it but not coded it. I think I'm ok for the extra wire too, see pic? ImageUploadedByTapatalk1369640423874539
I'm willing to travel a bit if needs be, I'm a bit lost when it comes to the coding stuff!!!
If your still stuck ill be travelling to kenilworth for the rest of this week, might be a bit far to travel though?
European car specialist burton on trent or one stop performance burton on trent or cctuning (chris) burton on trent they all have VCDS they can code it aslong as you tell them what to do and what needs changing etc etc
Thanks for your replies guys, I should've mentioned that I have a problem with it also! It has thrown up some codes and wiped out my power steering totally! It has thrown up codes for the steering angle sensor and the steering lock along with triggered the ESP light and also the steering wheel light! Is this common? I did a search but I'm really not to great with electronics and get lost in details!
I'll be driving about this week sometime, maybe up in Stoke area & I could sort your issue out.
Yeah mate, I had the battery off. But it's been to London and back since too. I tried to calibrate the steering angle sensor and it was doing nothing. Do you have much knowledge about the slip ring? I'm thinking maybe I disturbed it and that needs coding in or something? Do you think this could be the case?
I'm going to stoke myself at some stage but yeah I could drive there no problem, any help would be brilliant mate!
I'm not too far down in Nuneaton and can do it. PM me if you want to sort something.
There's an outfit in Long Eaton that advertises on eBay - they supply the OEM cruise and fit 'em so maybe they could sort you out.
Ping me a PM & I'll check which day I'm there for client.
