DAB Retro fit with BOSE amplifier.
jim potter
HI ALL,
i have a MMI 2g high system, with the Boe amplifer and stock FM radio.
i want to retro fit the DAB.
i have purchased the parts,inc power and optic leads, but am sturggling to find the am/fm unit.
i had initally though it was in the passenger side boot well, but that only appears to house the Bose amp?
Any pointers.
jim potter
For those with the same setup , it appears my FM Radio is intergrated with the Cd Player in the glove box (not multi changer).
has anyone retro fitted DAB with this setup?
jim potter
Unit fitted and working, stuck it behind the cd player and looped it in with the cable.
swapped out the FM aerial and suprisingly it does pick up quite a few stations on DAB.
What aerials are being used by most.
will the standard Audi unit work if i swap over the amp for it.
JimboRoad
Hi Jim,
What parts do you need to upgrade to DAB?
Waqqas_Zia
What parts did you buy? I'd defo want to do this
Sent from my SM-A226B using Tapatalk
jim potter
parts used are
AUDI DAB Radio Tuner Control Module 4E0035563​
its all in and working, but need to remove the c pillar trims. Any tips ?
