DAB to DAB + MMI 3G High
PVAU
Hello all, I've spent ages searching and trying to find suitable parts but I can't find an answer anywhere to my query.
I have a 2010 A4 B8 with MMI 3G High, never been updated. Unit in boot is a 4F0 035 061 D
DAB works perfectly - but I do not have access to DAB+ stations.
Can I upgrade the system to receive DAB+?
Thanks alot
OliNix
DAB+ uses the same frequencies and antenna, it just uses different codecs.
I believe the unit in the B8.5 can decode DAB+. If you can tell me what channels are DAB+ I can confirm to you, and also the part number of my unit in the boot. I have a 2015 B8.5 with MMI 3G+.
To be honest it’s probably much easier to just get a RSNav unit which will work better, have modern tech and give you your elusive DAB+
PVAU
How are you ascertaining that you don’t have DAB+ and others do?
Missing radio stations - like Radio X.
Others are Capital Dance, Capital xtra, Capital extra reloaded, Smooth Chill, Smooth UK.
Thanks - if you have these perhaps I can just buy the newer tuner and swap them?
I did look quite heavily into RSNav, but got the feeling it was a little buggy - albeit with excellent support I don't want to regularly have to troubleshoot issues and deal with compromises.
Darren92
Thanks alot
Done this in my A6 recently.
DAB+ module added today to replace the normal DAB unit from 2009.
CP removed and jobs a good ‘un :) 4G0035061D for anyone interested.
17db7bdf-3171-49fa-bf83-fc7efdea2418-jpeg.244501
