Dashcam not running from usb
DreamInCode
Active Member
UK
Does any one run their dashcam from the usb port instead of the ciggy lighter port?
The dashcam goes into data transfer mode whenever I plug it in to any of the usb ports. This same cam used to run on my Merc A class from USB but doesn't in A3.
Probably because the USB port isn’t just a power port like a power bank or 12v socket adapter but also a data port. Even though the devices can’t talk to each other, the dash cam recognises the car’s USB port as data capable.
Reactions: DreamInCode
If you want to avoid it, buy a USB condom (it’s a thing...) disables the data pins
Reactions: JohnM100 and DreamInCode
Wow - every day is a learning day!
Now to wipe my browser history rather than have to answer why I was googling condom...... (aka USB data blocker)
Reactions: SamR92 and DreamInCode
You can cover the data pins with a bit of insulation tape, works a treat.
7K
770
865
