dead MAF? AFB 2.5 tdi
audi2.5tdi
could I have a dead MAF
car feels lack luster, was in my dads identical car at the weekend, much stronger than mine, no flat spots anywhere
mine is especially flat 2500-3200/3500 then seems to pick up again
i ran the log on VCDS this evening after spending the day changing the timing belts, wp, thermostat, all rollers, idles, tensioners, aux belts and tensioners, rollers
timed the fuel pump with VCDS
the log I ran was on measuring block 3, i have the excel file, and according to the manual at 3k rpm the reading should be 850-900mg/h
im getting
@3039 RPM
MAF specified 792.9
MAF Actual 451.4
is the MAF toast?
Did it occur after the belt change?
Did you lock the crank and cams when you changed the belt?
VCDS will only time the pump.
No was like this before, I did lock the cams, crank, injection pump them time with VCDS when warm..
the injection pump timing was retarded before I started, between the middle and bottom line, now nicely between the middle and top lines
Swap the maf with your dad's car, if it goes better then it's duff...
not going to see him for a fortnight as hes off to scotland
ive just picked a new bosch one up from Euro car parts
much better, hopefully will equate to better fuel economy aswell!
still not convinced its running 100% though
