But do you think that if one of the motor went bad, I wouldn't get an error through scan?
Should I change it anyway just to see if that solves it?
On the A6 there used to be a common fault where the drivers side vent were hot and the passenger side vents were cold, it was not caused by the distribution housing inside the car, it was a fault with a coolant valve inside the engine bay. The fault happened on my C6 and after replacing the valve the temperature was normal again on both sides. Maybe worth looking at the A3 coolant system diagrams to see if there is a similar valve system on the 8V models.
This what what the valve unit looks like on the A6.
That's my problem exactly. Frozen wife i will look into it. Thank you though
Appreciate the guidance Craig, thank you. If the settings 'respond more passively' in eco setting, what exactly happens? Does it just take longer to adjust to temperature variations, or what?According to http://www.manualesaudi.com/AudiA3/en_GB/onboard/o_m00248.htm
The "eco" mode*1) is activated if you press the AUTO button briefly while automatic mode is active. Fuel is saved in "eco" mode* because the settings respond more passively. The "eco" mode* is on when eco appears in the console display. The "eco" mode*is deactivated when you press the AUTO button again
See part 10: HOSES & LINES.. Volkswagen (vw.com)That I got it but I just can't seem to find the control valve in my engine bay. There are no diagram for this, I looked for days...
I don't think the S3 has such a valve, I believe all the 'mixing and diverting' of hot air is done in the cabin via the heater flap motors rather than a valve in the engine bay diverting hot water into the cabin, I'm pretty sure hot water is piped into the cabin permanently and then distributed as required by the heater flap motors. I may be wrong of course. FYI I still have the some problem, I'm currently unemployed again due to COVID so I just can't justify giving an Audi an open cheque to sort it out.That I got it but I just can't seem to find the control valve in my engine bay. There are no diagram for this, I looked for days...
You are correct in relation to the 8V platform not having individual heat exchange valves. The ones pictured above are for the A6 which has a 2 zone heater core. The valves limit coolant flow to each side of the heater core depending on selected temperature in each zone for that system. For that platform they have been known to hold air pockets and seize up.
We do have valve in our system which controls coolant flow to our single zone heater core (component 10 in alpesh26's link above). This is used to divert coolant to the rest of the engine if not heat is requested by the climate control head. As mentioned in a previous post, this valve may be a culprit but symptoms would be no heat out of all vents or limited heat but equal across all vents. These N82 valves have been known to fail and let coolant into the connector so may be worth checking to be safe.
If you are experiencing issues with just one vent, it is most likely due to a temp sensor or flap motor inside the cabin. I would also make sure you verify the issue with the climate system set to Auto and Eco mode turned off. If you still have an issue, check faults and see if there are any range faults for any flap motor. There have been cases where these flap motors can freeze up. I would run the basic setting (via VCDS) to relearn all flap motor end stops and see if that fixes the issue. If it returns, most likely you will need a new flap motor.
Lastly, the temp sensor in the ducts can give a false reading (I have not seen this though). Simply run the system as above and use a temp gauge in the vent outlet. Compare your reading to what the measuring values are reading in the climate control head.
VCDS will be your friend here as it can help you complete the above diagnosis. Hope that helps you out.
My issue is the passenger vent blows quite a lot hotter than the drivers vent so even with the climate set to very low the passenger side always blows warm/hot (not ideal at all in the Summer). Audi re-learned all the motors flaps their start and end points which made no difference and they didn't see any error codes associated with any of the heating system. I also ruled out the temp sensors behind the vents by swapping them over and still having hotter air from the passenger side.
The blend flap was the conclusion I came to, it was a while ago now so I may not be remembering correctly but I tried to get at the blend motor myself and simply couldn't without taking the whole dash out but I'm sure I got a torch down the center heater vents and could see the blend flap operating correctly. Whether what I was looking at was the actual blend flap I can't be sure. Unless anyone knows an easier way of actually getting eyes on the blend flap and/or its motor I'm lost for what to do next.
Mine definitely was not normal because in the summer my passenger side roasted whoever was in the passenger seat. Since the AC recharge it's very cool on both sides now.I think it is normal..
When I turn AC on mine drivers side is cold but passengers is warm or less cold
Or looks like over years it will get blocked one side or vice versaMine definitely was not normal because in the summer my passenger side roasted whoever was in the passenger seat. Since the AC recharge it's very cool on both sides now.
Hi T1000
Where did you get the kit from?
Hi
Hi
Thanks for that. Audi dealer diagnosed fault under Audi Approved Warranty as corrosion on condenser causing a leak. After consulting a friend who is a registered gas safe engineer I would be wary of putting a sealer in an AC system on a car you want to keep. He pointed out it can block small pipes and parts causing compressors to fail which are about £500.
Also you need to drain the AC system and apply a vacuum to remove all moisture as well as you have to use a known weight of gas or you can over stress the AC system including the compressor.
Glad it worked for you and tempted to try but pushing dealer to pay for repair.
Thanks again for the help.
Most AC places add a leak tracer when doing a regas anyway.
If the system has a leak and been left open then the filter drier needs replaced as that absorbs all the moisture.
When doing an aircon regas the vacuum process is done for two reasons and the first is to see if the system will hold a vacuum and the second is so that the system will draw in the new refrigerant in to the system.
As for leak additive only time will tell if it causes any problems.
With a dealer regas or a diy regas the main thing that needs to be checked is the system pressure, yes over charging the system does add extra stress to the compressor but that’s the same whether dealer or diy.
A trained aircon specialist will check pressures to make sure the system is healthy pretty much the same as the diy version.
Usually if the system is over charged then the first thing you notice is that the system doesn’t chill properly because the pressure is too high the compressor cuts in and out .
HiNo worries.
I topped up the system only. So no concern really.
I’d already had the AC service at the dealer (Oct 2019) and it was around early spring in 2020 when I noticed the passenger side wasn’t as cold.
A top up with the can has restored it.
I’ll be getting the system properly emptied then filled later in the year.
I’ve a friend who is an AC engineer and he advised me on topping it up.
Hi
My condenser has a split in it, pics attached. You can see the split on drivers side (UK) if you look into the front grill. Must have had moisture in it that ate its way out.
Yes but the fault looks like corrosion from inside causing a crack. Rubbish VW group design putting the dryer inside the condenser but Audi do recommend a 2 year AC service which I assume includes dryer replacement and re gas?Your condenser is more exposed than mine on the RS3.
