Well my drivers door unit has finally given up so it will only lock but not unlock from the remote. Thankfully I can lock & unlock manually with the key, the only bad part being that doing it this way the alarm doesn't turn off!
I've had the door lock unit out & one of the micro switches in the lock has totally disintegrated & as Audi in there infinite wisdom have glued it in place I can't even replace the part.
So does anyone know the part for the front driver door actuator I stupidly forgot to note it when I had it out the door! Also is the 3dr lock the same as the 5dr lock?
Thanks.
Thanks.
